I am trying to set up a switch by template to perform multiple actions on turn_on and turn_off. The value_template is working but I can’t get any actions to run. Any ideas, please?
immersion1:
friendly_name: "Immersion 1"
unique_id: immersion1
value_template: "{{ is_state('climate.immersion_1_thermostat','on') }}"
turn_on:
- action: climate.set_preset_mode
entity_id: climate.immersion_1_thermostat
preset_mode: home
- action: climate.turn_on
data: {}
turn_off:
preset_mode: away
- action: climate.turn_off
data: {}
- switch:
- name: Immersion 1
icon: mdi:water-boiler
state: "{{ is_state('climate.immersion_1_thermostat','on') }}"
turn_on:
- service: climate.set_preset_mode
preset_mode: home
- service: climate.turn_on
turn_off:
preset_mode: away
- service: climate.turn_off
value_template:
> state:
(new format)
- action:
> - service:
Mikefila
(Mike Fila)
May 3, 2025, 5:02pm
3
krskrab:
- action:
> - service:
It’s the other way around action
is the current key. They also need to add the platform: template
key and value.
switch:
switches:
immersion1:
value_template: "{{ is_state('switch.source', 'on') }}"
turn_on:
- action: switch.turn_on
entity_id: switch.target
- action: light.turn_on
entity_id: light.target
brightness_pct: 40
turn_off:
- action: switch.turn_off
- action: light.turn_off
https://www.home-assistant.io/integrations/switch.template/#multiple-actions-for-turn_on-or-turn_off
My configuration.yaml file contains the following line:
switch: !include switch.yaml
and the lines that I posted were cut out of my switch.yaml file which contains plenty of switches that work:
switches:
# for Immersion Heaters #
immersion_1:
turn_on:
metadata: {}
data: {}
entity_id:
- climate.immersion_1_thermostat
metadata: {}
preset_mode: home
entity_id:
turn_off:
metadata: {}
data: {}
entity_id:
metadata: {}
preset_mode: away
entity_id:
immersion_2:
unique_id: immersion2
value_template: "{{ is_state('climate.immersion_2_thermostat','on') }}"
turn_on:
metadata: {}
data: {}
entity_id:
- climate.immersion_2_thermostat
metadata: {}
preset_mode: home
entity_id:
turn_off:
metadata: {}
data: {}
entity_id:
metadata: {}
preset_mode: away
entity_id:
I actually used the HA page that you mentioned Template Switch - Home Assistant as the basis for code.
This is really confusing me as I have an automation which delivers the desired outcome and I just wanted a simple “manual” option for my dashboard.
alias: 18c. Predbat immersion control
description: ""
triggers:
- trigger: state
entity_id:
- binary_sensor.predbat_iboost_active
to: "on"
- trigger: state
entity_id:
to: "off"
conditions: []
actions:
- choose:
- conditions:
- condition: trigger
id:
- iBoost_on
sequence:
metadata: {}
data: {}
entity_id:
metadata: {}
preset_mode: home
entity_id:
metadata: {}
data: {}
entity_id:
metadata: {}
preset_mode: home
entity_id:
- conditions:
id:
- iBoost_off
sequence:
metadata: {}
data: {}
entity_id:
metadata: {}
preset_mode: away
entity_id:
metadata: {}
data: {}
entity_id:
metadata: {}
preset_mode: away
entity_id:
mode: single
So,after building some screens, it looks like the switch works insofar as it turns the immersion heater on, but the displayed status of the climate helper doesn’t reflect that.
So what I really need to achieve is to get the climate helper and card to reflect the current situation.
This looks a lot like this thread
Thermostat Card Buttons Not Updating? so I probably need to close this one and head on over there. Thanks.
