Hey guys,
i want to display a specific attribute of an entity in my dashboard.
How can i create a template sensor that has the “countdown” attributes of the following antity as a state or attributes?
Thank you!
stop_id: "8910"
stop_name: Feuerwache Am Steinhof
departures:
- line: 46B
direction: Wilhelminenberg
platform: "1"
time_planned: 2026-01-18T15:29:00.000+0100
time_real: 2026-01-18T15:29:00.000+0100
countdown: 13
barrier_free: true
folding_ramp: false
type: ptBusCity
disturbances: []
- line: 46B
platform: "1"
time_planned: 2026-01-18T15:44:00.000+0100
time_real: 2026-01-18T15:44:00.000+0100
countdown: 28
barrier_free: true
folding_ramp: false
type: ptBusCity
disturbances: []```
{{ state_attr('sensor.example', 'departures') | map(attribute='countdown') | list }}
This works, thank you so much!!
Last question: I would like to add “min” as a suffix to the values, how would i do this in your code?
AFAIK, there’s no built-in function to iteratively append strings across a list, so one way to do it is use a macro and the apply function:
{% macro append(root,post)%}{{- root~post -}}{% endmacro %}
| map(attribute='countdown') | map('apply', append, ' min') | list }}
Awesome, thank you so much! I lied with “last question”, cause i have another one ^^
Your initial code gives back a list of 3 attributes, but i would limit it to just 2 values. Is this possible?
Sure, use list slicing …
{{ ( state_attr('sensor.example', 'departures')
| map(attribute='countdown') | map('apply', append, ' min') | list )[:2] }}
(Taras)
January 18, 2026, 10:42pm
8
It’s possible to use regex_replace for that purpose.
| map(attribute='countdown') | map('regex_replace', '(\d+)', '\\1 min') | list )[:2] }}
Regex pattern explanation
(\d+) is a capturing group designed to grab any number of digits.
\\1 is a backreference that contains whatever was found by the first capturing group. Half the battle of getting this to work is knowing that Home Assistant’s flavor of regex uses a double -backslash for backreference.
EDIT
Corrected the regex pattern.
