Template to use existing value when new value is not present
I have an MQTT topic that sends data updates. Sometimes a field is not present, and sometimes it returns -1 if there’s no data available.
So what I’m trying to do is build a sensor so that non-present data will use the existing value.
I tried
binary_sensor:
  - platform: mqtt
    state_topic: "thermostat"
    payload_on: 1
    payload_off: 0
    value_template: >
      {% if value_json.tstate is defined and value_json.tstate != -1 %}
        {{ value_json.tstate }}
      {% else %}
        {{ states('binary_sensor.boiler_on') }}
      {% endif %}
But on the cases where there’s no valid data then I get an error in the log:
2019-03-27 21:40:35 WARNING (MainThread) [homeassistant.components.mqtt.binary_sensor] No matching payload found for entity: Boiler on with state_topic: thermostat
How can I use the current state, or alternatively skip updating the state?
Here’s why:
A binary_sensor’s valid states are on and off. That means this:
will return either on or off, depending on its current state.
In your value_template you have:
      {% else %}
      {% endif %}
It means when else is executed, it will return either on or off, depending on the current state of binary_sensor.boiler_on.
The problem is that value_template has to produce something that matches one of these values:
    payload_on: 1
    payload_off: 0
Neither on or off will ever match 1 or 0 and that’s why you get the warning message No matching payload found for ...
Oh, I see!
So would a template like this work better (and delete the payload_on/off lines) ?
value_template: >
  {% if value_json.tstate is defined and value_json.tstate == 1 %}
    on
  {% elif value_json.tstate is defined and value_json.tstate == 0 %}
    off
  {% else %}
  {% endif %}
No. Your template still uses {{ states(binary_sensor.boiler_on') }} which will return on or off and never 1 or 0.
Try this:
    value_template: >
      {% else %}
        {{ 1 if states('binary_sensor.boiler_on') == 'on' else 0 }}
      {% endif %}
Ah, OK, I can see what you’re doing here (forcing everything to be 0 or 1, and so matching a payload_on/off setting). I’ll give that a try. Thanks!
Out of curiousity, wouldn’t it be “cleaner” to force the good values to return the expected value for the default on/off ? So if I don’t have any payload_on or payload_off values, force the received values to be on/off ?
OK, so based on your suggestion this seems to work, and didn’t trigger a warning on bad data
  - platform: mqtt
    payload_on: 1
    payload_off: 0
    value_template: >
      {% else %}
      {% endif %}
I guess I don’t understand why
- platform: mqtt
  value_template: >
      on
      off
    {% else %}
    {% endif %}
Caused errors. Wouldn’t this match the default values for on/off ?
No. The value_template must produce results that match payload_on and payload_off. If you read the documentation for MQTT Binary Sensor, the default values for payload_on and payload_off are: ON or OFF (uppercase, not lowercase).
Your value_template uses lowercase on and off so they will fail to match the default values for payload_on and payload_off.
In addition, states('binary_sensor.boiler_on') returns on or off so you’d need to use a filter to convert the states to uppercase.
      {{ states('binary_sensor.boiler_on') | upper }}
I hope this makes it all clearer now.
Oh, case sensitivity!
I never expected the current value of sensor (“on”) to not match the default valid input to a sensor (“ON”) . I wrote my template to match values in the states table. That was my mistake!
But, yes, this explains everything. Odd. Unexpected. But explainable :slight_smile:
Thanks!
You’re welcome!
Tag one of those posts as ‘solution’ so others can easily find it in the thread.
