Template tools design change
Why does it look like this?
Isn’t this easier to read?
I understand that you first want to direct to help with the tools. But it’s only the first time you open the page that it will be confusing with the help at the bottom.
And when the lines are across each other it’s easier every time.
I know they won’t match up when you do loops and multi lined if’s and such but most of the time you just want to compare a few things and it would be easier if they where in line with each other.
Don’t forget to vote for your own request.
