HI,
back again with this sensor:
circadian_light:
friendly_name: 'Circadian light'
unit_of_measurement: 'mired'
value_template: >
{% if is_state('sun.sun' , 'above_horizon') %}
{{ (float(states('sensor.length_of_day_factor') | round (5)) *
(float(state_attr('sun.sun','azimuth') )-180)**2 + 175) | round }}
{% elif (as_timestamp(state_attr('sun.sun','next_dusk'))) -
(as_timestamp(state_attr('sun.sun','next_setting'))) < 0 or
(as_timestamp(state_attr('sun.sun','next_rising'))) -
(as_timestamp(state_attr('sun.sun','next_dawn'))) < 0 %}
350
{% else %}
390
{% endif %}
as you can see ive already added type float
to both sides of the multiplication but still this error pops up at startup. what could be changed to mitigate that? I added, because without it, the same error reported. cant use int, because it simply isn’t…
this is the sensor it takes into account.
length_of_day_factor:
friendly_name: 'Length of day' # factor for circadian light calculation'
value_template: >
{% set daylength = ( (as_timestamp(state_attr('sun.sun','next_setting')) -
as_timestamp(state_attr('sun.sun','next_rising')) ) /
3600) + 24 %}
{{ ((daylength*-0.0063616)+0.11131) | round(5) }}
2018-10-08 14:40:59 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.circadian_light fails
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 221, in async_update_ha_state
await self.async_device_update()
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 347, in async_device_update
await self.async_update()
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/sensor/template.py", line 180, in async_update
self._state = self._template.async_render()
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/template.py", line 132, in async_render
return self._compiled.render(kwargs).strip()
File "/usr/local/lib/python3.6/site-packages/jinja2/asyncsupport.py", line 76, in render
return original_render(self, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/jinja2/environment.py", line 1008, in render
return self.environment.handle_exception(exc_info, True)
File "/usr/local/lib/python3.6/site-packages/jinja2/environment.py", line 780, in handle_exception
reraise(exc_type, exc_value, tb)
File "/usr/local/lib/python3.6/site-packages/jinja2/_compat.py", line 37, in reraise
raise value.with_traceback(tb)
File "<template>", line 3, in top-level template code
TypeError: can't multiply sequence by non-int of type 'float'
