I want to be able to go through a list of entities provided by an integration and match one of them based on a case-insensitive comparison of an attribute, and then select a different value from the entity.
Here’s an example:
{# Pretend this is a variable that will be handed to this script by
something external, i.e., a converstation assistant. #}
{% set incoming_variable_from_ai = 'Kitchen speaker' -%}
{%- set ids = integration_entities('music_assistant') | list -%}
{%- set names = ids
| map('state_attr', 'friendly_name')
| map('lower')
| list -%}
{%- set index = names.index(incoming_variable_from_ai | lower) -%}
{# I'm writing the entity_id here, but this is where I would
get a different attribute #}
{{ ids[index] }}
I feel like there is a simpler way to accomplish this that I’m just not seeing. This also works, but if only there were a filter that selectattr
accepted that could do a case-insensitive comparison. I didn’t see one while googling. Did I miss something?
{# An alternate method which loops over the state objects in order
to compare an attribute case-insensitively, but then select
{%- for ps in integration_entities('music_assistant') | expand -%}
{%- if ps.attributes.friendly_name | lower == incoming_variable_from_ai | lower -%}
{{ ps.entity_id }}
{%- break -%}
{%- endif -%}
{%- endfor -%}
