I have upgraded to HA2026.4.4 from the last HA2026.3 version.
Now found below error in the logs which occurs 300 times a day!
Last line says HW is undefined but it doesn't mention any integration or something, where to look??
2026-05-08 09:57:42.347 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template<template=({{ HW }}) renders=4218>
File "/usr/src/homeassistant/homeassistant/helpers/template/__init__.py", line 465, in async_render
render_result = render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template/context.py", line 45, in render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.14/site-packages/jinja2/environment.py", line 1295, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.14/site-packages/jinja2/environment.py", line 942, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 1, in top-level template code
jinja2.exceptions.UndefinedError: 'HW' is undefined
File "/usr/src/homeassistant/homeassistant/helpers/template/__init__.py", line 583, in async_render_to_info
render_info._result = self.async_render( # noqa: SLF001
variables, strict=strict, log_fn=log_fn, **kwargs
File "/usr/src/homeassistant/homeassistant/helpers/template/__init__.py", line 467, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: UndefinedError: 'HW' is undefined
