I use an api from mygekko to control my covers. Its works fine but I want to get ride of the errors in my log:
Template variable error: 'state' is undefined when rendering '{% if state('cover.shutter_tim_window', 'open') %} mdi:blinds-open {% else %} mdi:blinds {% endif %}'
my code is:
- platform: rest
resource: http://192.168.178.33/api/v1/var/blinds/status
username: admin
password: xxxxx
authentication: basic
json_attributes:
- item0
- item1
- item2
- item3
- item4
- item5
- item6
- item7
- item8
- item9
- item10
- item11
value_template: "OK"
scan_interval: 1
- platform: rest
resource: http://192.168.178.33/api/v1/var/roomtemps
username: admin
password: xxx
json_attributes:
- item0
- item1
- item2
- item3
- item4
- item5
- item7
- item8
scan_interval: 1
sensors:
test_temperature:
device_class: temperature
unit_of_measurement: "°C"
value_template: >-
'{{ states.sensor.mygekko_temps.attributes["item7"]["sumstate"]["value"].split(";")[1] }}'
shell_command:
shutter_up: "curl 'http://192.168.178.33/api/v1/var/blinds/item{{ device_id }}/scmd/set?value=1&username=admin&password=xxx'"
shutter_down: "curl 'http://192.168.178.33/api/v1/var/blinds/item{{ device_id }}/scmd/set?value=-1&username=admin&password=xxx'"
shutter_stop: "curl 'http://192.168.178.33/api/v1/var/blinds/item{{ device_id }}/scmd/set?value=0&username=admin&password=xxxxx"
shutter_position: "curl 'http://192.168.178.33/api/v1/var/blinds/item{{ device_id }}/scmd/set?value=P{{ position }}&username=admin&password=xxx'"
change_temp: "curl 'http://192.168.178.33/api/v1/var/roomtemps/item7/scmd/set?value=K%2$s&username=admin&password=xxxxx'"
cover:
covers:
shutter_tim_window:
friendly_name: "Timfenster"
device_class: shutter
position_template: '{{ ((states.sensor.mygekko_rollos.attributes["item8"]["sumstate"]["value"].split(";")[1] | int) *-1 +100) }}'
open_cover:
service: shell_command.shutter_up
device_id: 8
close_cover:
service: shell_command.shutter_down
device_id: 8
stop_cover:
service: shell_command.shutter_stop
device_id: 8
set_cover_position:
service: shell_command.shutter_position
data_template:
device_id: 8
position: "{{ position *-1 +100 }}"
icon_template: >-
mdi:blinds-open
{% else %}
mdi:blinds
{% endif %}
what I’m doing wrong?
