Templates organized in folders
Hi everyone,
I'm newbie to all of this and still learning. I've just started messing around with YAML, but I've run into a doubt I can't quite figure out.
I created a new template that adds some sensors, and I put it in config/templates/pronostico_tiempo.yaml.
Then, in my configuration.yaml, I added this:
template: !include templates/pronostico_tiempo.yaml
It works perfectly, but if I create a new one, I'd have to manually add it there again. Is there any way to automatically load all the template files inside that folder?
I've already tried using !include_dir_merge_named, but I couldn't get it to work.
Thanks a lot!
Cheers.
Try
template: !include_dir_merge_list template
It works fine! Thank you!
Cheers!
