Templating Blueprint Script Fields: Looking for options, alternatives, or workarounds
I was playing around with a Blueprint, but I've hit a road block. The goal was to set it up so that users could add song names and their corresponding codes using an Object selector at the blueprint level, then derive the script's field selects options from that list of objects...
blueprint:
  name: ESPHome Play RTTTL
  description: |
    This script should be adaptable to any device using the ESPHome RTTTL Component.
    This script expects your device to include the following action in it's API component configuration:
    api:
      actions:
        - action: rtttl_play
          variables:
            tone: string
          then:
            - rtttl.play:
                rtttl: !lambda 'return tone;'
  domain: script
  input:
    rtttl_action:
      description: |
        The RTTL action suplied by your ESPHome device.
        If you can't find it try searching for "esphome." or "rtttl"
      selector:
    tune_collection:
      name: Tune Collection
      selector:
        object:
          label_field: Tune Name and Code
          description_field: |
            Use the "Name" field to define how you want the tune to appear for selection in the script.
            Paste the RTTTL Code for that tune in it's field. You can add new tunes at anytime.
          multiple: true
          fields:
            name:
              label: Name
              selector:
                text: null
            rtttl_code:
              label: RTTTL Code
              selector:
                text: null
mode: queued
variables:
  tune_collection: !input tune_collection
  rtttl_action: !input rtttl_action
  action_id: "{{ rtttl_action[0]['action']|default('esphome.esphome_starter_kit_play_rtttl', true) }}"
  tune_names: "{{ tune_collection | map(attribute='name') | list }}"
fields:
  tune:
    selector:
      select:
        multiple: false
        options: "{{tune_names}}"  #This is what doesn't work
sequence:
  - action: "{{ action_id }}"
    metadata: {}
      song_string: "{{ tune_collection|selectattr('name','eq', tune) | map(attribute= 'rtttl_code') | first }}"
EDIT:
I think the only options are:
  1. Use a Text selector in the script field... maybe with some bare bones search logic, since I don't think there's any way to do proper fuzzy search.
  2. Set up multiple inputs with Object selector instead of just one... but that would make the GUI kind of gross.
Anyone have any better ideas....?
