Templating in Automation's Trigger IDs
Why something like this doesn’t work?
trigger: state
entity_id:
  - schedule.christmas_lights_schedule
id: "{{ states('schedule.christmas_lights_schedule') }}"
The result is "{{ states('schedule.christmas_lights_schedule') }}" while I’m expeting on or off.
Can’t see anything in the docs about using templates in trigger IDs - I suspect they’re just strings.
Strings only.
@alex3025
You can get the entity_id that triggered from a template, without needing to add a trigger id
trigger.to_state.entity_id
Oh, sad moment…
So should I use {{ states('trigger.to_state.entity_id') }} to get the state of the schedule?
you have 2 ways,
trigger.to_state.state
or
states(trigger.to_state.entity_id)
So I could do something like this? (as automation condition)
condition: template
value_template: "{{ trigger.to_state.state == 'on' }}"
sure, but why are you doing that? You can just explicitly say that in the trigger.
trigger: state
entity_id:
to: 'on'
I want to use a single schedule trigger to trigger on and off statuses
triggers:
  - trigger: state
    entity_id:
conditions: []
actions:
  - choose:
      - conditions:
          - condition: or
            conditions:
              - condition: template
        sequence:
          - type: turn_on
            device_id: 610aa9a1e720ddf89d6a4d3c11341317
            entity_id: d99fcc55ff51d75e397bc330299eeefc
            domain: switch
            enabled: true
mode: restart
what’s the off going to look like?
alias: example
description: Turn christmas lights on and off as per schedule
triggers:
  - trigger: state
    entity_id:
conditions: []
actions:
  - action: "switch.turn_{{ trigger.to_state.state }}"
      entity_id: switch.your_switch
mode: single
