The following RESTful sensor retrieves the temperature from one of the locations from the “Badetassen” API. The GET returns an array with the data from 50+ locations, and using the json_attributes_path I am able to filter out a single location:
- platform: rest
device_class: temperature
unit_of_measurement: "°C"
resource: "https://prdl-apimgmt.lyse.no/apis/t/prod.altibox.lyse.no/temp/1.0/api/location/"
method: GET
scan_interval: 300
headers:
accept: "application/json"
content-type: "application/json"
Authorization: "Bearer 9df43895-3d09-30d5-afe4-db2bf92a86f0"
json_attributes_path: "$.[?(@.id==10)]"
json_attributes:
- lastReadingTime
- lastTemperature
- GPSLat
- GPSLong
- PictureURL
# - Name
value_template: >
{% for x in value_json %}
{% if (x.id == 10 and (now() - as_datetime(x.lastReadingTime)) < timedelta( hours = 3 )) %}
{{x.lastTemperature}}
{% endif %}
{% endfor %}
Next I wanted to get a hold of the temperatures from all the 4 sensors in my area, without doing the accessing the API four times. That should be possible by changing json_attributes_path as I have done below to get the array I want and then adding template sensors for each separate location. However, when I do this it the attributes are gone. It looks like they are not recognized when they are arrays? How do I solve this?
- platform: rest
method: GET
scan_interval: 300
headers:
json_attributes_path: "$.[?(@.area_id==4)]"
value_template: "OK" #dummy value to avoid 255 char limit
The array should look like this:
[{'id': 107, 'Area_id': 4, 'Name': 'Kyvannet', 'GPSLat': '63.404594', 'GPSLong': '10.342120', 'PictureURL': 'https://las-smc-pd-cdn-badetemp.azureedge.net/images/Kyvannet_badeplass.jpeg', 'lastReadingTime': '2021-10-04T16:56:02+02:00', 'lastTemperature': '9.8'}
{'id': 11, 'Area_id': 4, 'Name': 'Munkholmen', 'GPSLat': '63.451380', 'GPSLong': '10.384790', 'PictureURL': 'https://las-smc-pd-cdn-badetemp.azureedge.net/images/Munkholmen_badeplass.JPG', 'lastReadingTime': '2022-06-01T13:09:52.562000+02:00', 'lastTemperature': '11.2'}
{'id': 10, 'Area_id': 4, 'Name': 'Sjøbadet', 'GPSLat': '63.435770', 'GPSLong': '10.390610', 'PictureURL': 'https://las-smc-pd-cdn-badetemp.azureedge.net/images/Sjobadet_badeplass.JPG', 'lastReadingTime': '2022-06-01T13:08:46.895000+02:00', 'lastTemperature': '7.5'}]
