I have an input.number defined in HA:
- platform: homeassistant # Set drum high level from HA
name: "Set drum high level"
entity_id: input_number.drum_high_level_setpoint #defined in homeassistant
and need to use it in sensor.in_range:
condition:
sensor.in_range:
above: !lambda 'return ((id(high_level_setpoint).state));'
but I can’t get it to pass validation.
Is my syntax incorrect or can’t the range be templated?
The docs don’t say it can, so, if that is the case, how else could I achieve this?
Well, having exhausted all options, it seems it’s not doable.
So, for completeness, here’s my solution using a script. Not ideal, but as far as I can see it’s the only way to achieve it.
esphome:
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "water-level-test-hotspot"
password: !secret OTA_password
captive_portal:
web_server:
port: 80
auth:
username: admin
time:
- platform: homeassistant # Sync time with HA
i2c:
sda: GPIO4
scl: GPIO5
scan: true
ads1115:
- address: 0x48
continuous_mode: on
- name: "Drum water level sensor"
platform: ads1115
ads1115_id: ads1115_48
multiplexer: 'A0_GND'
update_interval: 1s
unit_of_measurement: "Cm"
icon: "mdi:gauge"
accuracy_decimals: 3
# gain: 6.144 #(measures up to 6.144V)
gain: 4.096 #(measures up to 4.096V)
# gain: 2.048 #(measures up to 2.048V)
# gain: 1.024 #(measures up to 1.024V)
# gain: 0.512 #(measures up to 0.512V)
# gain: 0.256 #(measures up to 0.256V)
# filters:
# - median:
# window_size: 7
# send_every: 4
# send_first_at: 3
on_value:
then:
- script.execute: set_drum_level_binary_sensors
- platform: homeassistant # Set drum low level from HA
name: "Set drum low level"
entity_id: input_number.drum_low_level_setpoint #defined in homeassistant
binary_sensor:
- platform: status
name: "Koi pond pressure Status"
- platform: template # Drum low level is up to HA
name: "Drum low level"
name: "Drum high level"
script:
- id: set_drum_level_binary_sensors
then:
- if:
condition:
- lambda: 'return id(drum_water_level_sensor).state <= id(low_level_setpoint).state;'
then:
- binary_sensor.template.publish:
state: ON
state: OFF
- if:
condition:
- lambda: 'return id(drum_water_level_sensor).state >= id(high_level_setpoint).state;'
then:
state: OFF
state: ON
- if:
condition:
and:
- lambda: 'return id(drum_water_level_sensor).state < id(high_level_setpoint).state;'
- lambda: 'return id(drum_water_level_sensor).state > id(low_level_setpoint).state;'
then:
state: OFF
state: OFF
