Temporary trigger stop
I have a flow where every minute a trigger takes place.
If I press a push button this trigger should be interrupted until 11:00, how do I do this in node red?
In the HA helpers section create a toggle and use it in a current state node. Everyday at 11 turn off the toggle even if it wasn’t turned on.
[{"id":"90be47305c2aa6d7","type":"inject","z":"8e6ef4f6cbb13d83","name":"every minute","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":450,"y":900,"wires":[["227a57c834978ca8"]]},{"id":"227a57c834978ca8","type":"api-current-state","z":"8e6ef4f6cbb13d83","name":"stop my flow toggle","server":"","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":690,"y":900,"wires":[["6b499185ddf5047c"]]},{"id":"6b499185ddf5047c","type":"debug","z":"8e6ef4f6cbb13d83","name":"debug 4","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":920,"y":900,"wires":[]},{"id":"801e1676d56fd91c","type":"inject","z":"8e6ef4f6cbb13d83","name":"Everyday @ 11","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"00 12 * * *","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":470,"y":980,"wires":[["dc57c3f14b68bb1a"]]},{"id":"dc57c3f14b68bb1a","type":"api-call-service","z":"8e6ef4f6cbb13d83","name":"turn off flow toggle","server":"","version":7,"debugenabled":false,"action":"","floorId":[],"areaId":[],"deviceId":[],"entityId":[],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"","service":"","x":730,"y":980,"wires":[[]]}]
