TERNCY-SD01 connects, but doesn't fully configures
So I’m trying to use the TERNCY-SD01 smart dial, according to blakadder it should work fine with ZHA. I do get it found/configured/connected, but it doesn’t appear to be fully configured even though it says it’s completed.
I did find this error in the logs while pairing
Logger: frontend.js.latest.202302020
Source: components/system_log/__init__.py:254
First occurred: 11:37:13 PM (4 occurrences)
Last logged: 11:38:10 PM
http://homeassistant:8123/frontend_latest/218278ed.js:256:484 TypeError: this._clusterConfigurationStatuses is undefined
Shows that it’s using what appears to be the correct quirks Quirk: zhaquirks.terncy.sd01.TerncyKnobSmartDimmer
The ZigBee Device diagnostics are:
  "home_assistant": {
    "installation_type": "Home Assistant OS",
    "version": "2023.2.5",
    "dev": false,
    "hassio": true,
    "virtualenv": false,
    "python_version": "3.10.7",
    "docker": true,
    "arch": "x86_64",
    "timezone": "America/Los_Angeles",
    "os_name": "Linux",
    "os_version": "5.15.90",
    "supervisor": "2023.01.1",
    "host_os": "Home Assistant OS 9.5",
    "docker_version": "20.10.22",
    "chassis": "vm",
    "run_as_root": true
  "custom_components": {
    "midea_dehumidifier_lan": {
      "version": "0.8.12",
      "requirements": [
        "midea-beautiful-air==0.9.15"
    "hacs": {
      "version": "1.30.1",
      "requirements": [
        "aiogithubapi>=22.10.1"
    "midea_ac": {
      "version": "0.1.25",
      "requirements": [
        "msmart==0.1.25",
        "pycryptodome",
        "midea"
    "frigate": {
      "version": "2.1.0",
      "requirements": []
    "adaptive_lighting": {
      "version": "1.4.1",
      "requirements": []
  "integration_manifest": {
    "domain": "zha",
    "name": "Zigbee Home Automation",
    "config_flow": true,
    "documentation": "https://www.home-assistant.io/integrations/zha",
    "requirements": [
      "bellows==0.34.7",
      "pyserial==3.5",
      "pyserial-asyncio==0.6",
      "zha-quirks==0.0.92",
      "zigpy-deconz==0.19.2",
      "zigpy==0.53.0",
      "zigpy-xbee==0.16.2",
      "zigpy-zigate==0.10.3",
      "zigpy-znp==0.9.2"
    "usb": [
        "vid": "10C4",
        "pid": "EA60",
        "description": "*2652*",
        "known_devices": [
          "slae.sh cc2652rb stick"
        "vid": "1A86",
        "pid": "55D4",
        "description": "*sonoff*plus*",
        "known_devices": [
          "sonoff zigbee dongle plus v2"
        "vid": "10C4",
        "pid": "EA60",
        "known_devices": [
          "sonoff zigbee dongle plus"
        "vid": "10C4",
        "pid": "EA60",
        "description": "*tubeszb*",
        "known_devices": [
          "TubesZB Coordinator"
        "vid": "1A86",
        "pid": "7523",
        "known_devices": [
        "vid": "1A86",
        "pid": "7523",
        "description": "*zigstar*",
        "known_devices": [
          "ZigStar Coordinators"
        "vid": "1CF1",
        "pid": "0030",
        "description": "*conbee*",
        "known_devices": [
          "Conbee II"
        "vid": "10C4",
        "pid": "8A2A",
        "description": "*zigbee*",
        "known_devices": [
          "Nortek HUSBZB-1"
        "vid": "0403",
        "pid": "6015",
        "description": "*zigate*",
        "known_devices": [
          "ZiGate+"
        "vid": "10C4",
        "pid": "EA60",
        "known_devices": [
          "ZiGate"
        "vid": "10C4",
        "pid": "8B34",
        "description": "*bv 2010/10*",
        "known_devices": [
          "Bitron Video AV2010/10"
    "codeowners": [
      "@dmulcahey",
      "@adminiuga",
      "@puddly"
    "zeroconf": [
        "type": "_esphomelib._tcp.local.",
        "name": "tube*"
        "type": "_zigate-zigbee-gateway._tcp.local.",
        "name": "*zigate*"
        "type": "_zigstar_gw._tcp.local.",
        "name": "*zigstar*"
        "type": "_slzb-06._tcp.local.",
        "name": "slzb-06*"
    "dependencies": [
      "file_upload"
    "after_dependencies": [
      "onboarding",
      "usb",
      "zeroconf"
    "iot_class": "local_polling",
    "loggers": [
      "aiosqlite",
      "bellows",
      "crccheck",
      "pure_pcapy3",
      "zhaquirks",
      "zigpy",
      "zigpy_deconz",
      "zigpy_xbee",
      "zigpy_zigate",
      "zigpy_znp"
    "is_built_in": true
  "data": {
    "ieee": "**REDACTED**",
    "nwk": 47039,
    "manufacturer": "Xiaoyan",
    "model": "TERNCY-SD01",
    "name": "Xiaoyan TERNCY-SD01",
    "quirk_applied": true,
    "quirk_class": "zhaquirks.terncy.sd01.TerncyKnobSmartDimmer",
    "manufacturer_code": 4648,
    "power_source": "Battery or Unknown",
    "lqi": 24,
    "rssi": null,
    "last_seen": "2023-02-25T23:41:25",
    "available": true,
    "device_type": "EndDevice",
    "signature": {
      "node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4648, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
      "endpoints": {
        "1": {
          "profile_id": 260,
          "device_type": "0x01f2",
          "in_clusters": [
            "0x0000",
            "0x0001",
            "0x0003",
            "0x0020",
            "0xfccc"
          "out_clusters": [
            "0x0019"
    "active_coordinator": false,
    "entities": [
        "entity_id": "sensor.bathroom_volume_battery",
        "entity_id": "button.bathroom_volume_identify",
    "neighbors": [],
    "routes": [],
    "endpoint_names": [
        "name": "undefined_0x01f2"
    "user_given_name": "Bathroom Volume",
    "device_reg_id": "c99cb047f53a067ab39b74b4fcffa727",
    "area_id": "bathroom",
    "cluster_details": {
      "1": {
        "device_type": {
          "name": "undefined_0x01f2",
          "id": 498
        "profile_id": 260,
        "in_clusters": {
          "0x0000": {
            "endpoint_attribute": "basic",
            "attributes": {},
            "unsupported_attributes": {}
          "0x0001": {
            "endpoint_attribute": "power",
            "attributes": {
              "0x0021": {
                "attribute_name": "battery_percentage_remaining",
                "value": 138
              "0x0020": {
                "attribute_name": "battery_voltage"
              "0x0031": {
                "attribute_name": "battery_size"
              "0x0033": {
                "attribute_name": "battery_quantity"
          "0x0003": {
            "endpoint_attribute": "identify",
            "attributes": {},
          "0x0020": {
            "endpoint_attribute": "poll_control",
            "attributes": {},
          "0xfccc": {
            "endpoint_attribute": null,
            "attributes": {},
        "out_clusters": {
          "0x0019": {
            "endpoint_attribute": "ota",
            "attributes": {},
