Tesla Fleet: how to reduce API usage
Running HA Core 2025.1.3.
I’ve installed the latest Tesla Fleet integration for a few days and found that its API usage approaches $0.40 per day. That brings it over the $10/month baseline usage. I have one EV and 3 Powerwalls.
Is there a way to reduce the number of API calls? The doc says the integration class is “Cloud Polling”, so is there a way to configure the poll frequency?
Thanks for your help!
Hi wwho,
Thanks for the info! It works great!
If this suggestion solves your problem, please consider clicking the solution button to close the thread.
@wwho Which of all these entities are you polling by automation? I am at the same problem that some day the costs go to 0,50€ per day.
Ok dumb question. What did you select as the target for the Home Assistant Core Integration: Update entity? The only options I get are specific entities. If you just pick a random entity that is tied to a Tesla Fleet device (i.e. my car), will it then pull an update for all of the entities in one go?
