Tesla Powerwall3 integration
I am attempting to add a powerwall3 to HA via the native integration. I am getting the following error.
An unknown error occurred: Powerwall api error: API returned status code ‘424: Failed Dependency’ with body: {“code”:424,“message”:“No system details, please run enumeration”}
From some of the research I have done it appears that the API for the powerwall 3 is broken. I am wondering if there is any process forward on this or if headway is being made on a revision?
Useful tips forward are appriciated. I am new to the HA community but have been in enterprise automation for some time so please excuse nievity.
Hi @adminadam did you find a solution to this?
I have just got a powerwall 3 & I am considering getting HA to integrate with my heat pump (daikin Altherma 3), car charger (myenergi zappi) and energy supplier (Octopus UK).
If the HA integration for PW3 is not avaialbe I may not bother.
Many thanks
I have a Powerwall 2 and it has recently stopped talking to the native HA integration. A bit of googling suggest that Tesla are killing the local api on the Powerwall 2 so I wouldn’t be surprised if it is just not there on the PW3.
The Tesla Custom Integration GitHub - alandtse/tesla: Tesla custom integration for Home Assistant. This requires a refresh token be generated by third-party apps to login. is a cloud based alternative that still works fine with my PW2 - perhaps worth a try?
Pros it can actually control the powerwall - eg, set battery reserve level, cons it’s cloud-based so real time monitoring of power is out.
Good luck
Thanks for the reply.
I now realise that my installation is a PW3 with a Gateway 2
Do you know of the above custom integration would work with PW2 and GW2? Or how I may find out?
Also, is the above custom integration accessed via HACS (or, if not how is it accessed? if that sounds silly, pleas bare in mind I have not actually played with HA yet.)
Many thanks
The link I posted has full installation instructions for a HACs and a manual install.
Try it and see if it works is the only way you will know for sure - just follow the instructions carefully and make sure not to skip any steps.
Good luck
Hi all, did anyone ever got anywhere with this? Looking at options for controlling PW3 charging with HA.
