TEST - iluminize Remote
blueprint:
  name: iluminize ZG2819S-RGBW
  description: Control lights with a iluminize 511.344 RGBW Remote
  domain: automation
  input:
    remote:
      description: iluminize 511.344 remote to use
      selector:
        device:
          integration: deconz
          manufacturer: iluminize
          model: ZG2819S-RGBW
    target_light:
      description: The light(s) to control
      selector:
          entity:
            domain: light
    colour_ref:
      name: Colour Temperature Refence
      description: The light to use as a colour temp reference
      selector:
        entity:
          domain: light
    working_scene:
      description: The scene to be triggered when the 1 button is pressed
      selector:
        entity:
          domain: scene
    sunset_scene:
      description: The scene to be triggered when the 2 is pressed
      selector:
        entity:
          domain: scene
    party_scene:
      description: The scene to be triggered when the 3 is pressed
      selector:
        entity:
          domain: scene
    night_scene:
      description: The scene to be triggered when the 4 is pressed
      selector:
        entity:
          domain: scene
    force_brightness:
      name: Force turn on brightness
      description: Force the brightness to the set level below, when the "on" button
        on the remote is pushed and lights turn on.
      default: false
      selector:
        boolean: {}
    brightness:
      description: Brightness of the light(s) when turning on
      default: 50
      selector:
        number:
          min: 0.0
          max: 100.0
          mode: slider
          step: 1.0
          unit_of_measurement: '%'
    step_value:
      name: Brightness increment/decrement percent
      description: Set the step percent value for brightness and color warmth
      default: 10
      selector:
        number:
          min: 1.0
          max: 20.0
          mode: slider
          step: 1.0
  source_url:
mode: restart
max_exceeded: silent
variables:
  force_brightness: !input 'force_brightness'
  step_value: !input 'step_value'
  colour_ref: !input 'colour_ref'
- platform: event
  event_type: deconz_event
  event_data:
    device_id: !input 'remote'
- variables:
    event: '{{ trigger.event.data.event }}'
- choose:
  - conditions:
    - '{{ event == 1008 }}'
    sequence:
    - choose:
      - conditions: '{{ force_brightness }}'
        sequence:
        - service: light.toggle
          target: !input 'target_light'
            brightness_pct: !input 'brightness'
      default:
  - conditions:
    - '{{ event == 2008 }}'
    sequence:
    - service: light.turn_on
        brightness_step_pct: '{{ step_value }}'
        transition: 1
  - conditions:
    - '{{ event == 3008 }}'
    sequence:
        brightness_step_pct: -{{ step_value }}
        transition: 1
  - conditions:
    - '{{ event == 4008 }}'
    sequence:
        color_temp: '{{state_attr(colour_ref, ''color_temp'')|int + 60}}'
  - conditions:
    - '{{ event == 1006 }}'
    sequence:
        color_temp: '{{state_attr(colour_ref, ''color_temp'')|int - 60}}'
  - conditions:
    - '{{ event == 2006 }}'
    sequence:
        xy_color:
        - '{{ trigger.event.data.xy.0 }}'
        - '{{ trigger.event.data.xy.1 }}'
  - conditions:
    - '{{ event == 1005 }}'
    sequence:
    - service: homeassistant.turn_on
      entity_id: !input 'Button1'
  - conditions:
    - '{{ event == 2005 }}'
    sequence:
      entity_id: !input 'Button2'
  - conditions:
    - '{{ event == 3005 }}'
    sequence:
      entity_id: !input 'Button3'
  - conditions:
    - '{{ event == 4005 }}'
    sequence:
      entity_id: !input 'Button4'
Why do you want to publish it if it’s a test? Also, you need to put 3 backticks on their own line, then the blueprint, then another 3 backticks on their own line.
Has any progress been done on this? Would be awesome to get the 511.344 working!
Hello
how did you pair this device with Home Assistant?
Has anyone this remote in use ? If yes, could you share how you did it ?
