Is there any way to test the resources of the scrape sensor? I’m not familiair with beautiful soup and having a hard time scraping certain data. At the moment I’m testing several options before (sometimes) succeeding and every time I want to test a resource I have to restart Hass which delays a lot…
I created a notebook which is showing how the scrape
sensor works and should help to identify the relevant part in the HTML.
Thanks, I’ll dive into this next weekend!
Thank you. The notebook is very good to help with this sensor.
I have a question because I’m trying to use with my web www.pcdemano.com and selecting 'b" it can found, for example, a data in 8 position.
Unfortunately the scrape sensor doesn’t work properly
- platform: scrape
resource: http://www.pcdemano.com
select: ‘b:nth-of-type(8)’ #users
and it seems there is an error
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/sensor/scrape.py”, line 120, in update
value = raw_data.select(self._select)[0].text
IndexError: list index out of range
Not idea?
Thank you in advance
Hard to tell if the site is gone.
I seem to be getting the same, tho i’m pretty sure i’m doing it wrong, as i’m trying to scrape from an RSS feed (as i can’t seem to get the feedreader to work)
Me have errors too:
- platform: scrape
resource: https://www.endesaclientes.com/precio-luz-pvpc.html?d=Any
select: “#actualPrice”
The object is a ID (actualPrice)…
Maybe because the web have JS? Ajax?
In a wonderful twist of irony, your notebook appears to now be gone. Any chance of a reshare? I’m trying to decipher the scrape sensor and would love to see your work!
is it possible to scrape from https://app.proofofhumanity.id ?
I can’t get it to work.
Kind regards
midijunkie
Found this when browsing the repository…
