Looking at this some more, I think the add-on exposes an event to HASS via MQTT. There is a list of available events on the info page of the add-on. So I think it should be possible to catch the event. It would however be good if the battery info was exposed as a battery sensor. I’ve not successfully listened to them yet, but I’ll continue to play.
EDIT: I should add I’ve listened to other texecom2mqtt events, just not log events yet.
fyi - I believe a sensor could be created from the MQTT events using the HA MQTT Integration (MQTT Sensor - Home Assistant). That said, I don’t know exactly what the event is that would indicate the low battery and how it is formatted, so I’ve currently written some NodeRed to monitor for events with ‘Battery’ in them. I expect it will be a year…
So i’ve fixed the above and the MQTT is connected to texecom2mqtt. The logs are showing that the zones are being fetched correctly however I’m missing an entity - I’ve checked the MQTT is showing are discoverable and no default prefix’s have been changed.
2021-11-15 15:58:13 - INFO: Starting texecom2mqtt v1.1.6...
2021-11-15 15:58:13 - INFO: Connected to alarm, sleeping for 1 second...
2021-11-15 15:58:14 - INFO: Connection ready
2021-11-15 15:58:14 - INFO: Fetched serial number: xxxx
2021-11-15 15:58:14 - INFO: Logging in
2021-11-15 15:58:14 - INFO: Successfully logged in
2021-11-15 15:58:14 - INFO: Connected to MQTT
2021-11-15 15:58:14 - INFO: Fetched panel info: Premier Elite 64 (V4.02.01LS1)
2021-11-15 15:58:15 - INFO: Fetched Area A: House Alarm
2021-11-15 15:58:15 - INFO: Fetched Area B: Area B
2021-11-15 15:58:15 - INFO: Fetched Area C: Area C
2021-11-15 15:58:15 - INFO: Fetched Area D: Area D
2021-11-15 15:58:18 - INFO: Fetched Zone 9: Keypad (Type: Entry/Exit 1; Areas: A)
2021-11-15 15:58:18 - INFO: Fetched Zone 10: Front Door (Type: Guard; Areas: A)
2021-11-15 15:58:19 - INFO: Fetched Zone 11: Hall PIR (Type: Guard; Areas: A)
2021-11-15 15:58:19 - INFO: Fetched Zone 12: Front Lounge PIR (Type: Guard; Areas: A)
2021-11-15 15:58:19 - INFO: Fetched Zone 13: Rear Lounge PIR (Type: Guard; Areas: A)
2021-11-15 15:58:20 - INFO: Fetched Zone 14: Patio Doors (Type: Guard; Areas: A)
2021-11-15 15:58:20 - INFO: Fetched Zone 15: Kitchen PIR (Type: Guard; Areas: A)
2021-11-15 15:58:20 - INFO: Fetched Zone 16: Back Door (Type: Entry/Exit 1; Areas: A)
2021-11-15 15:58:20 - INFO: Fetched Zone 17: Landing PIR (Type: Guard; Areas: A)
2021-11-15 15:58:21 - INFO: Fetched Zone 18: Zone 18 (Type: Custom; Areas: A)
2021-11-15 15:58:35 - INFO: Updating all zone states...
2021-11-15 15:58:35 - INFO: Updating all area states...
2021-11-15 15:58:35 - INFO: Application ready
Was hoping someone could help me. I am trying to disarm the alarm via homekit. But it just spins, as it probably requires the code to be entered, any idea where I can put the code in the config.
My texecom config is -
texecom:
host: 192.168.0.xx # Required: Texecom panel IP address
udl_password: "xxxx" # Optional: UDL password programmed in the panel. Note: this is NOT the code used to arm/disarm the panel (default: 1234)
port: 1001 # Optional: port used to connect to the panel (default: 10001)
mqtt:
host: xxxxxx # Optional: broker URL or IP address (default: localhost)
port: 1883 # Optional: broker port (default: 1883 or 8883 for TLS connections)
prefix: texecom2mqtt # Optional: topic prefix to use (default: texecom2mqtt)
username: xxxx # Optional: broker user (default: none)
password: xxxxx # Optional: broker password (default: none)
client_id: texecom2mqtt # Optional: client ID (default: random)
keepalive: 30 # Optional: keepalive in seconds (default: 10)
retain: true # Optional: retain (default: true)
retain_log: false # Optional: retain on log messages (default: false)
homeassistant:
discovery: true # Optional: enable Home Assistant discovery (default: false)
prefix: homeassistant # Optional: Home Assistant MQTT topic prefix (default: homeassistant)
areas:
- id: A
full_arm: armed_away
part_arm_1: armed_night
part_arm_2: armed_home
code_arm_required: false
code_disarm_required: true
code: "xxxx"
log: debug
My HA config is - configuration.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
`# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml`
I’ve bought and installed a ComWiFI via Com3 but I’m now stuck with the below.
I’ve connected the ComWiFI to my wifi
2021-11-26 16:14:26 - INFO: Starting texecom2mqtt v1.1.6...
2021-11-26 16:14:26 - INFO: Connected to alarm, sleeping for 1 second...
2021-11-26 16:14:28 - INFO: Connection ready
2021-11-26 16:14:28 - INFO: Fetched serial number: XXXXXX
2021-11-26 16:14:28 - INFO: Logging in
2021-11-26 16:14:28 - ERROR: Could not log in
2021-11-26 16:14:28 - INFO: Connected to MQTT
2021-11-26 16:14:28 - ERROR: write after end
2021-11-26 16:14:32 - ERROR: This socket has been ended by the other party
Given it’s fetching the serial number, the IP details must be correct, i know the UDL password is correct, so whats up?
Do I need to configure the ComWiFi inside the panel somehow?
Thank you Daniel for making this add-on available.
I have been using this for some time now and it’s been working like a charm all along. About a week ago it all of a sudden stopped working, and I can for all the tea in China not figure out how to get it up and running again. Since it stopped working I have updated the app to v2 and also Wintex to 7.2.3 to be able to login again. When I start the add-on the log (debug log level) is this:
Is there anyone who can point me in the right direction? How do I open the panel socket?! I am lost here and am really missing the convenience of having lights go on triggered by PIR or activating/deactivating the alarm when we leave the house and come back.
Do you just have a smartcom or that plus a comip? Do you connect from wintex via ip or via smart connect (or whatever it is called)? Have you disconnected wintex before starting the addon? That last question may not matter depending on answers to the first two, but if only smartcom and connect via ip, the wintex connection will lockout the addon connection.
Thanks for your reply. I do have both a smartcom and a ComIP set up. Wintex I connect through the smartcom and Wintex is not connected when I try to connect from the add-on.
I connect via my ComWifi and it got stuck a few weeks ago, I think I logged into it and restarted it, I imagine it is the same with the ComIP. Depends whether you connect the addon via it. You can also reset the SmartCom by taking the front off and holding down a button, I forget which. There is a thread a posted on the Texecom forum asking about it.
Also you could try connecting wintex via the same route you use for the addon, if it connects then the problem is likely with your addon config.
I’ve been struggling with the integration but resolved most issues. I now have a config related issue. I’ve tried various config syntax but there seems to be multiple versions floating around here.
(node:1) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'match' of undefined
at /snapshot/app/node_modules/better-ajv-errors/lib/modern/helpers.js:26:53
at Array.forEach (<anonymous>)
at makeTree (/snapshot/app/node_modules/better-ajv-errors/lib/modern/helpers.js:21:13)
at _default (/snapshot/app/node_modules/better-ajv-errors/lib/modern/helpers.js:116:16)
at _default (/snapshot/app/node_modules/better-ajv-errors/lib/modern/index.js:27:45)
at validate (/snapshot/app/dist/config.js:58:24)
at Object.loadConfig (/snapshot/app/dist/config.js:41:16)
at /snapshot/app/dist/index.js:11:29
at Object.<anonymous> (/snapshot/app/dist/index.js:74:3)
at Module._compile (pkg/prelude/bootstrap.js:1433:22)
(node:1) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
(node:1) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will t
If I remove the areas section, it runs, so there’s something astray with that section.
Not sure if its case sensitive or not, but yours seems to be backwards to the example in the documentation:
- id: house # Required: area number or ID (e.g. 'detached_garage', '4A' or '2')
name: House Alarm # Optional: override the area name (default: area name in panel)
Other than that, I think you’d have to check the area names against the panel/Wintex, or try with the area numbers as the ID instead?
I notice you have four spaces before the “-” on your first array item. YAML is a stupid syntax, so could this be the cause? (I only have two spaces on mine)
