This isn’t a specific issue with the app as such, it’s more of an issue that I’m having with getting it working.
I can read the state of all zones as expected but commands to arm/part-arm the system do not work for me.
The last message I get is…
2026-09-14 13:28:06 - TRACE: Received response for ArmArea command (sequence: 31) - 0606
When I initiate the command, the alarm keypad gives a single beep and the event log says “CORRUPT EVENT”.
Is anyone able to help with what exactly the response of “0606” means, what is the panel reporting back?
If anyone has/uses this app and would be willing to change their log level to TRACE and tell me what messages you get when you arm/part-arm the system from HA, it would be very much appreciated.
I’ve double checked all the alarm settings and even tried changing the UDL password at both ends multiple times.
log: trace
cache: false
texecom:
host: 192.168.1.67
udl_password: '1234'
mqtt: {}
areas:
- id: a
full_arm: armed_away
part_arm_1: armed_night
part_arm_2: armed_home
zones: []
homeassistant:
discovery: true
