Text in lamdba exposed as RBG light to ESPhome
Hey so this is a pointless little feature I have been working on. Am not sure if someone has done it before or not but I figured I would share. You must have 3 unassigned GPIO to make this work. Text color is adjustable in HA like it was an RGB light entity:
esphome:
  friendly_name: Mini Display TV - Yellow
esp8266:
  board: esp01_1m
external_components:
  - source:
      type: git
      url: https://github.com/rletendu/esphome.git
      ref: st7789_nobuffer_202312
    components: [st7789v]
logger:
api:
ota:
  platform: esphome
wifi:
  ssid: "wifissid"
  password: "wifipassword"
  ap:
    ssid: "display"
spi:
  clk_pin: GPIO14
  mosi_pin: GPIO13
  interface: hardware
output:
  - platform: esp8266_pwm
    pin: GPIO05
    frequency: 1000 Hz
    inverted: true
  # Dummy RGB outputs (not connected to physical pins)
    pin: GPIO4  # Dummy pin
    inverted: false
    pin: GPIO12  # Dummy pin
    inverted: false
    pin: GPIO15  # Dummy pin
    inverted: false
light:
  - platform: monochromatic
    output: pwm_output
    restore_mode: RESTORE_AND_ON
  # Virtual RGB light for text color control
  - platform: rgb
    red: output_red
    green: output_green
    blue: output_blue
    restore_mode: ALWAYS_ON
font:
  - file: "gfonts://Orbitron"
time:
  - platform: homeassistant
switch:
    entity_id: switch.air_purifier_outlet1
    entity_id: weather.home
    attribute: temperature
    internal: true
# Text sensors for weather and location information
text_sensor:
    internal: true
display:
  - platform: st7789v
    model: "Custom"
    spi_id: spihwd
    height: 240
    width: 240
    offset_height: 0
    offset_width: 0
    dc_pin: GPIO00
    reset_pin: GPIO02
    eightbitcolor: true
    update_interval: 30s
    spi_mode: mode3
    lambda: |-
      // Read RGB values from the virtual light entity
      float r = id(text_color).current_values.get_red() * 255;
      float g = id(text_color).current_values.get_green() * 255;
      float b = id(text_color).current_values.get_blue() * 255;
      Color text_color = Color(r, g, b);
      // Display the time in 12-hour format
      it.strftime(0, 80, id(dspfont), text_color, TextAlign::BASELINE_LEFT, "%l:%M", id(esptime).now());
      // Display the date in abbreviated weekday, MM/DD format (no year)
      it.strftime(0, 130, id(dspfont_medium), text_color, TextAlign::BASELINE, "%a %m/%d", id(esptime).now());
      // Display current weather condition with text_color
      it.print(0, 140, id(dspfont_small), text_color, id(weather_condition).state.c_str());
      // Display current temperature under the weather condition with text_color
      String temp_str = "Temp: " + String(id(temperature).state) + " °F";
      it.print(0, 170, id(dspfont_small), text_color, temp_str.c_str());
      // Display "Party mode: ON" or "No fun allowed" with text_color
      if (id(air_purifier_outlet1).state) {
        it.printf(0, 230, id(dspfont_small), text_color, TextAlign::BASELINE_LEFT, "Party mode: ON");
      } else {
        it.printf(0, 230, id(dspfont_small), text_color, TextAlign::BASELINE_LEFT, "No fun allowed");
Nice workaround !
By the way, to avoid problems in future, select correct board.
Which board type this is was specified by Installing ESPhome on GEEKMAGIC Smart Weather Clock (smalltv/pro) - #71 by ra.jeevan
I am not sure which esp8266 variant the box I have contains to be sure
