I have been using a 7.5 epaper display for a while now and show different values of some enities like power produced by my photovoltaic system.
Now I installed a new 2.13 epaper display with a ESP8266.
Describing text is shown correct on the display, but the text sensor I use keeps empty. I use the same settings in the 7.5 display where it is working perfect:
Here parts of the used code:
So its showing the correct sensor value but, its not printing the name/id of the sensor that goes with the sensor value?
You might tey setting an actual (name:) for the sensor or at the very least just type the name you want printed with the value. You can manually add a static string into the printf command
Oh, I thought you were saying it was showing a sensor value(123.12) but no sensor name with it. Have you verified that HA text sensor is showing any state/text for the Shelly sensor? I’m not seeing anything noticeably wrong with the printf statement. Make sure your Text sensor is getting data.
Could this be a problem, using the same sensor id?
The 7.5" working display works with an ESP32. The 2.13 runs with a ESP8266, but this should be working also, shouldn’t it?
Ok, I found the issue - was a silly mistake. As I integrated the device in homeassistant there seems to be an issue, because as I had a look at the EPS devices the new one was not configured. After configured it again it displays the data.
