The color of the bage differs from the state of the input_number
Hi! Help me, pls. I need to change the color of the number with card_mod that differes from the input_number
Now I have:
type: entities
entities:
  - entity: sensor.nositel_local
    card_mod:
      style: |
        :host {
          color:
            {% if states(config.entity) | int <= 17 %}
              red
            {% elif states(config.entity) | int >= 17 %}
              green
            {% endif %}
And it works well.Tried to change to this, but it is not working(
type: entities
entities:
    card_mod:
      style: |
        :host {
          color:
            {% if states(config.entity) | int <= input_number.target_temp_kuh %}
              red
            {% elif states(config.entity) | int >= input_number.target_temp_kuh %}
              green
            {% endif %}
states(config.entity) | int <= states('input_number.target_temp_kuh') | int
Not working(
If I put “21” - it works
If I put states(‘input_number.target_temp_kuh states’) - not working
Now the states of input number is 21
Miss from my side, corrected above :grimacing:
I’m trying to set the third IF value between -1 and +1 from the input number value, not working, can you help me?
type: entities
entities:
    card_mod:
      style: |
        :host {
          color:
            {% if states(config.entity) | float < states('input_number.target_temp_kuh') | float -1 %}
              blue
            {% elif states(config.entity) | float > states('input_number.target_temp_kuh') | float +1 %}
              red
            {% elif ((states(config.entity) | float > states('input_number.target_temp_kuh') | float -1) && (states(config.entity) | float < states('input_number.target_temp_kuh') | float +1)) %}
              green
            {% endif %}
Try this for your third IF:
{% elif (states(config.entity) | float > states('input_number.target_temp_kuh') | float -1) and (states(config.entity) | float < states('input_number.target_temp_kuh') | float + 1 ) %}
With the risk of being hammered down by the gurus in the forum I think you should use and instead of && since that is used in javascript but Jinja is used in templating.
I also sorted out all your different () which were all over the place.
I strongly recommend to use Templating under development tools (which you should enable under settings) to test your templates. There it is easier to find problems. :slight_smile:
I made it simpler, I wrote
{% else %}
Thank you very much!
