I have a chart where I can choose to display data from either my AP solar panels, SolarEdge (SE), or both.
I can also select day, month, or year views, though those aren't relevant to my question.
When I select ‘SE’ or both, the bars are wide; however, when I select ‘AP’, the width changes and they become narrow.
Does anyone have any idea why this happens and how to fix it?
Here is my YAML
type: vertical-stack
cards:
- type: horizontal-stack
cards:- type: custom:mushroom-chips-card
alignment: center
chips:- type: template
content: >
{% if is_state('input_select.pv_grafiek_installatie','APSystems')
AP
{% else %}
AP
{% endif %}
tap_action:
action: call-service
service: input_select.select_option
entity_id: input_select.pv_grafiek_installatie
option: APSystems - type: template
content: >
{% if is_state('input_select.pv_grafiek_installatie','SolarEdge')
SE
{% else %}
SE
{% endif %}
tap_action:
option: SolarEdge - type: template
content: |
{% if is_state('input_select.pv_grafiek_installatie','Beide') %}
Beide
{% else %}
Beide
{% endif %}
tap_action:
option: Beide
- type: template
alignment: center
content: |
{% if is_state('input_select.pv_grafiek_periode','Vandaag') %}
Vandaag
{% else %}
Vandaag
{% endif %}
tap_action:
entity_id: input_select.pv_grafiek_periode
option: Vandaag - type: template
content: |
{% if is_state('input_select.pv_grafiek_periode','Maand') %}
Maand
{% else %}
Maand
{% endif %}
tap_action:
option: Maand - type: template
content: |
{% if is_state('input_select.pv_grafiek_periode','Jaar') %}
Jaar
{% else %}
Jaar
{% endif %}
tap_action:
option: Jaar
- type: template
- type: conditional
conditions:- entity: input_select.pv_grafiek_installatie
state: Beide
card:
alignment: center
content: |
{% if is_state('select.pv_grafiek_weergave','Gestapeld') %}
Gestapeld
{% else %}
Gestapeld
{% endif %}
tap_action:
service: select.select_option
entity_id: select.pv_grafiek_weergave
option: Gestapeld - type: template
content: |
{% if is_state('select.pv_grafiek_weergave','Vergelijken') %}
Vergelijken
{% else %}
Vergelijken
{% endif %}
tap_action:
option: Vergelijken
- type: template
- type: conditional
state: APSystems - entity: input_select.pv_grafiek_periode
state: Vandaag
card:
type: custom:apexcharts-card
header:
show: true
title: APSystems vandaag
graph_span: 24h
span:
start: day
apex_config:
chart:
height: 420
series:- entity: sensor.roof_ecu_216000394801_lifetime_energy
type: column
color: "#ff9800"
group_by:
duration: 1h
func: diff
- type: conditional
state: Maand
card:
header:
show: true
title: APSystems deze maand
graph_span: 31d
span:
start: month
apex_config:
chart:
height: 420
type: column
color: "#ff9800"
group_by:
duration: 1d
func: diff
- type: conditional
state: Jaar
card:
header:
show: true
title: APSystems dit jaar
graph_span: 1y
span:
start: year
apex_config:
chart:
height: 420
type: column
color: "#ff9800"
group_by:
duration: 1month
func: diff
- type: conditional
state: SolarEdge - entity: input_select.pv_grafiek_periode
state: Vandaag
card:
header:
show: true
title: SolarEdge vandaag
graph_span: 24h
span:
start: day
apex_config:
chart:
height: 420
series:- entity: sensor.solaredge_i1_ac_energy
type: column
color: "#ffd600"
group_by:
duration: 1h
func: diff
- type: conditional
state: Maand
card:
header:
show: true
title: SolarEdge deze maand
graph_span: 4d
span:
start: month
apex_config:
chart:
height: 420
type: column
color: "#ffd600"
group_by:
duration: 1d
func: diff
- type: conditional
state: Jaar
card:
header:
show: true
title: SolarEdge dit jaar
graph_span: 1y
span:
start: year
apex_config:
chart:
height: 420
type: column
color: "#ffd600"
group_by:
duration: 1month
func: diff
- type: conditional
state: Beide - entity: input_select.pv_grafiek_periode
state: Vandaag
card:
header:
show: true
title: PV-opbrengst vandaag
graph_span: 24h
span:
start: day
apex_config:
chart:
stacked: true
height: 420
type: column
color: "#ff9800"
group_by:
duration: 1h
func: diff - entity: sensor.solaredge_i1_ac_energy
type: column
color: "#ffd600"
group_by:
duration: 1h
func: diff
- type: conditional
state: Maand
card:
header:
show: true
title: PV-opbrengst deze maand
graph_span: 4d
span:
start: month
apex_config:
chart:
stacked: true
height: 420
type: column
color: "#ff9800"
group_by:
duration: 1d
type: column
color: "#ffd600"
group_by:
duration: 1d
func: diff
- type: conditional
state: Jaar
card:
header:
show: true
title: PV-opbrengst dit jaar
graph_span: 1y
span:
start: year
apex_config:
chart:
stacked: true
height: 420
type: column
color: "#ff9800"
group_by:
duration: 1month
type: column
color: "#ffd600"
group_by:
duration: 1month
func: diff
grid_options:
columns: 24
rows: auto
