The docs are wrong, how can I help?
In this page, it says, philips hue should show up as a configurator, but instead it shows up in configuration/integrations. Can I help fix this? Should I?
On the top right of the page there is a link to edit the page. Help to correct and improve the docs is highly appreciated!
Cool, not 100% sure how it should work right now though…
for example this is not true for me: When you configure the Hue bridge from Home Assistant, it writes a token to a file in your Home Assistant configuration directory. That token authenticates the communication with the Hue bridge. This token uses the Address of the Hue Bridge. If the IP address for the Hue Bridge changes, you will need to register the Hue Bridge with Home Assistant again. To avoid this you may set up DHCP registration for your Hue Bridge, so that it always has the same IP address.
But I also get some errors.
