The following works in Development Tool / Templates but the sensor in configuration.yaml has an error
This gives me exactly what I am looking for but will not translate in configuration.yaml, I am sure it could be more efficient and neater, but I need to understand before making it pretty. I don’t want to use powercalc, I want to understand the syntax.
{% set solinp =  states('sensor.sma_power') | float(0) %}
{% set nitfig =  states('sensor.pconsume') | float(0) %}
{% set suptogrid = states('sensor.sma_energy_meter_psupply') | float(0) %}
{{solinp}}
{{suptogrid}}
{{nitfig}}
{% if solinp < 0 and suptogrid == 0 %}
{{nitfig}}
{% elif solinp > 0 %}
{{solinp + nitfig }}
{% else %}
{{solinp - suptogrid}}
{% endif %}
the following template sensor does not pass syntax and i can find no answer to what I am doing wrong (again) Fails with or without the “-” in the if etc’s.
Error
      - name: current useage
        unique_id: current_useage
        unit_of_measurement: "W"
#        state_class: measurement
        device_class: power
        value_template >
          {% if solinp < 0 and suptogrid == 0 -%}
            {{nitfig}}
          {%- elif solinp > 0 -%}
            {{solinp}}
          {%- else -%}
            {{solinp}}
          {%- endif %}
This results in unknown
        device_class: power
        state: >
             nitfig
             solinp
           {% else %}
             solinp
           {% endif %}
value_Template missing the :
as i pasted in VS I Got this
then
What file are you putting this in and what integration key is it under?
What you’ve presented is a mash-up of legacy and current Template sensor syntax, so we need to know where you’re putting it to tell you which parts are right and wrong.
In the original post I said configuration.yaml
What integration key is it under?
Template
believe it or not I didnt have a space between : and > in the value_template line.
This stuff drives me totally fricking bananas.
Except now it is complaining it doesn’t have “state” ffs
put state: > and it is back to unknown
template:
  - trigger:
      - platform: time_pattern
        hours: /1
      - service: weather.get_forecasts
          type: daily
          entity_id: weather.k3ll3r # change to your weather entity in this line
        response_variable: daily
      - name: Weather Forecast Daily
        unique_id: weather_forecast_daily
        state: "{{ now().isoformat() }}"
        attributes:
          forecast: "{{ daily['weather.k3ll3r'].forecast }}" # change to your weather entity in this line
        device_class: power
        state: >
             {{nitfig}}
             {{solinp}}
           {% else %}
             {{solinp}}
           {% endif %}
#        state: >
#          {% set ssp = states('sensor.sma_power') | float(0) %}
#          {% set sems = states('sensor.sma_energy_meter_psupply') | float(0) %}
#          {% set dteu = states('sensor.sma_power') | float(0) - states('sensor.sma_energy_meter_psupply') | float(0) %}
#          {% set nteu = states('sensor.sma_power') | float(0) + states('sensor.sma_energy_meter_pconsume') | float(0) %}
#             {% if (dteu | float) > 0 %}
#                 dteu
#               {% elif nteu > 0 %}
#                  nteu
#               {% endif %}
#             {% else %}
#                dteu
#             {% endif %}
      - name: "Day Power"
        unique_id: power_during_the_day
        device_class: power
        unit_of_measurement: 'W'
        icon: mdi:alpha-a
        state: >
          {% set home_generated = states('sensor.sma_power') |float(0) %}
          {% set total_to_grid = states('sensor.sma_energy_meter_psupply') |float(0) %}
          {{ ((home_generated - total_to_grid) ) |round(1, default=0) }}
Oh boy do I hate File Editor, but VS is so OTT.
The problem … the “trigger” had the “-” before it so all I had was being treated as Trigger. (Hello Dave!)
for those who would like to know the syntax and structure!!
template:
  - trigger:
        hours: /1
          type: daily
  - sensor:
        attributes:
        device_class: power
        state: >
             {{nitfig}}
             {{solinp}}
           {% else %}
             {{solinp}}
           {% endif %}
Thank you Myle, although the problem was actually somewhere else. (See below)
Was it the - for trigger or sensor?
I ask so others can use your resolution in the future. Sensor had no dash in your posted code, but your solution has - sensor:
Trigger has the - in both iterations of posted code.
This will break your weather forecast sensor, as it relies on the data of the trigger. You need to do this:
template:
  - trigger:
        hours: /1
          type: daily
        attributes:
  - sensor:
        device_class: power
        state: >
             {{nitfig}}
             {{solinp}}
           {% else %}
             {{solinp}}
           {% endif %}
The sensor beloning to the trigger should be part of the trigger list item.
The sensors which are not trigger based, and not depending on that trigger should be under their own sensor list item.
Simplified example using multiple types and multiple triggers:
template:
  - trigger:
      - some trigger
      - name: a sensor based on the trigger
    binary_sensor:
      - name: a binary sensor based on the same trigger
  - trigger:
      - some other trigger used for other sensors
      - name: a sensor based on this other trigger
      - name: another sensor based on this other trigger
  - sensor:
      - name: a sensor which is state based, and not trigger based
      - name: another state based sensor
  - binary_sensor:
      - name: a state based binary sensor
