The official script doesn't install v0.92
as per the instructions here, this script installs the latest version of Home Assistant
https://raw.githubusercontent.com/home-assistant/hassio-installer/master/hassio_install.sh
I tried it on a debian machine, but it installs version 0.91.4 instead of version 0.92.
I’m I doing something wrong?
when did you try to run this script? 0.92 was only released late yesterday and it usually take a few hours for all the docker versions to be build and published.
This page will show you when the tag for your environment was built:
https://hub.docker.com/u/homeassistant
Would have thought it would pull 0.92 - I got the qemux86 for a generic Linux install this morning and the script would pull the latest. You can always upgrade.
yeah it seems it was updated 7 minutes ago. I guess I was just too eager to give it a try :slight_smile:
Nope, just run the installer again, and its the old version. I’ll wait.
1
At a guess it installs what it finds here https://s3.amazonaws.com/hassio-version/stable.json
