Tell me how to make the code. If there was no movement after a while (adjusted by the slider), the light turned off. Do not use Delay, as the automation does not work correctly with it. Thank you.
Hi there. Welcome. This should work, if you replace the motion sensor, input_number and light entity with yours.
- platform: state
entity_id: binary_sensor.your_motion_sensor_here # change this
to: 'on'
- platform: state
to: 'off'
for:
minutes: "{{ states('input_number.motion_delay') | int(0) }}"
- service: "light.turn_{{ trigger.to_state.state }}"
entity_id: light.your_light_here # change this
mode: single
