Hello, I am just trying to do what I thought would be a simple thing but now I have spent a couple of hours on this… I just want to add a constant to an entity value that I monitor. It is an electricity price that I want add a constant to so it will show what I will actually pay in the end (the utility company adds a cost per transferred kWh). There is no simple UI based way to do this if I understand this correctly, I have to create a “Template” and add it to configuration.yaml. So I add this to configuration.yaml:
I get the green light in the file editor but then HA can’t reboot and I get this error message:
The system cannot restart because the configuration is not valid: Integration error: state - Integration ‘state’ not found.
I am grateful for help to solve this -and I hope the answer is “there is a simpler way to do this”…
Thank you very much Tamsy, it works! Doesn’t show exactly how I want it, but I can work on that.
I am not used to code and to be honest I don’t want to take the time to learn. I’ve spent too much time on that in the past, I am just not good at it. Do you have any idea of why a basic functionality like this is not available in the frontend UI? Where you can just create new entities, without code, by picking entities to manipulate e.g. “entity 1 + entity 2” and call it “entity 3”? There must be a million use cases for this, and equally many people who prefer not to code.
Me neither. I’m more into system administration than into coding and I do rarely reply to questions regarding coding. However, those wrong indentations with your template above jumped straight into my eyes
I don’t remember what it’s called but I remember reading in the release notes for the December release that there is a new helper entity that returns the sum of two other sensors.
It should be configurable thru the UI like other helpers.
I did have a look at the helpers but couldn’t find anything useful there. If you find it, let me know! In this case however, I just want to add a constant to a sensor value.
