The system cannot restart because the configuration is not valid: Unexpected error calling config validator: ‘NodeStrClass’ object has no attribute ‘items’.
Registrador: homeassistant.components.websocket_api.http.connection
Fuente: components/websocket_api/commands.py:303
integración: Home Assistant WebSocket API (documentación, problemas)
What version of HA and OS do you have?
Hello rafa962,
What was the last thing you changed? It is most likely the problem.
If not that, check everything changed since the last reboot.
