There should be easier way to random or at least documentation
How does one put a random minutes delay in yaml?
There’s 100x posts saying to do it all sorts of different ways but I can’t frt any of them to work.
I propose it should be easier for newbies to understand rather than trawling throwmugh forum posts for 5 years ago.
    - delay:
        minutes: "{{ range(0, 60)|random|int }}"
So what’s your proposal to make it easier?
Using the forum’s search function seems easy enough.
https://community.home-assistant.io/search?q=Random%20delay%20
Here’s one that was marked with the Solution tag.
The principle is largely the same for most examples: specify a range of acceptable values and then choose one value at random.
Post what you tried but failed to work.
