I have created an automation to set a temperature in a NETATMO thermostat.
However, I cannot find the mode by which to set that temperature FOR A CERTAIN TIME, for a time duration, to make sure that when time finished, the thermostat returns to the scheduled temperature.
Automation is triggered by an event in Google Calendar.
Therefore, that event has a variable duration
Is it possible to calculate the DURATION as the difference between end time and start time of the calendar event, and then determine the duration of the temperature setup accordingly?
Ok so it has attributes but it does not generate an end “event” on the state bus you can trigger off. You will have to calculate the duration using a template sensor that subtracts the attributes.
It is also possible to control the trigger on the END event of the calendar
So I could “lower” the temperature when the event ends.
The problem is that when I raise the temperature, against the START event, the thermostat acquires a MANUAL CHANGE; this change is set for one hour.
If the event lasts for more than an hour, that’s when automatically at the end of the first hour of change the thermostat returns to the scheduled state.
Whereas I should make sure that the temperature remains set for the duration of the event…
Hi mla, did you slove that problem in the meanwhile? This option of duration missing is ruining the thermostat integration in my opinion. Who wants to set the heater for an hour only?
In the end, I developed a procedure to set the thermostat temperature repeatedly, for example every quarter of an hour, until the end time of the event in the calendar.
It’s not a “brilliant” solution, but at least it works.
