Thermostat from Tuya, showing wrong Info
I know the basic info of this question has been posted several times. I have created a sensor I call “AC Fixed” or something similar, where I adjusted the thermostat values. The problem with this is when using “Generic Thermostat” with the new sensor, allows me to have Cool/Heat mode, sure, but I cannot figure out how to add the dehumidifier option to this thermostat. I need to be able to adjust based on the humidity level reported by a sensor I have in my garage.
Here is the “Garage Fixed” generic thermostat showing the only options available. Am I missing something or is there a good workaround? Ideally I would just like to fix the original sensor, but I cannot find how to edit the value coming in from Tuya.
