I got an issue with Z-wave thermostat heatit-z-trm2fx + utility meter. After power outage thermostat is in first reading reporting 0.0kwh instead of real value. This makes than utility meter unusable because it measure difference. So every thermostat plug out/plug in it add to utility meter total of measured kwh. Is it possible to set this z-wave device to ingnore first zero readings? Thank you for any tips.
2019-07-11 12:57:55.169 Info, Node003, Received Meter report from node 3: Energy=0.0kWh
2019-07-11 12:57:55.169 Detail, Node003, Refreshed Value: old value=1.8, new value=0.0, type=decimal
2019-07-11 12:57:55.169 Detail, Node003, Changes to this value are not verified
2019-07-11 12:57:55.169 Detail, Node003, Notification: ValueChanged
2019-07-11 12:57:55.171 Detail, Node003, Notification: ValueChanged
2019-07-11 12:57:55.188 Detail, Node003, Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x03, 0x0e, 0x32, 0x02, 0x21, 0x54, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa7
2019-07-11 12:57:59.412 Detail, Node003, Refreshed Value: old value=false, new value=false, type=bool
2019-07-11 12:57:59.412 Detail, Node003, Changes to this value are not verified
2019-07-11 12:57:59.412 Info, Node003, Received Meter report from node 3: Energy=1.8kWh
2019-07-11 12:57:59.412 Detail, Node003, Refreshed Value: old value=0.0, new value=1.8, type=decimal
2019-07-11 12:57:59.412 Detail, Node003, Notification: ValueChanged
2019-07-11 12:57:59.414 Detail, Node003, Notification: ValueChanged
2019-07-11 12:57:59.431 Detail, Node003, Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x03, 0x0e, 0x32, 0x02, 0x21, 0x54, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa7
