Thermostat history isn't showing when cooling unless temperature changed too
My thermostat graph looks like this:
thermostat_run_history
I think it’s supposed to show a green bar under the line for hvac_action, but it only shows it for the first run after I changed the temperature in the morning. But the AC was on/off all night, but there’s no indication? It’s a Z-Wave Honeywell thermostat using OpenZWave.
Is there some alternative to show the history of hvac_action, like in a label or something as a list?
Well I don’t know what the problem is but I did solve it by putting my history in text form which I like very much.
For anyone else looking to do that, you can by first installing the logbook card
Since hvac_action is an attribute and not a sensor directly it won’t work, so you need to create a template sensor as well. Mine looks like this:
    # Sensor to track HVAC attribute (cooling, heating)
        sensors:
          hvac_action:
            friendly_name: HVAC Action
            entity_id: climate.thermostat_mode
            value_template: "{{ state_attr('climate.thermostat_mode', 'hvac_action') }}"
And the card definition:
    desc: true
    entity: sensor.hvac_action
    hiddenState:
      - None
      - Unknown
    state_map:
      - label: Idle
        value: idle
        icon: 'mdi:hvac'
      - label: Cooling
        value: cooling
        icon: 'mdi:air-conditioner'
      - label: Heating
        value: heating
        icon: 'mdi:air-filter'
    max_items: 10
    show:
      end_date: false
      start_date: true
    title: HVAC Running History
    type: 'custom:logbook-card'
It ends up looking like this:
Capture
