Is this a format issue? I get this error “No action defined, please define an ‘action:’ key” when pasting this into the action tab under developer tools:
- id: "T6 thermostat Poll Temperatures"
alias: T6 thermostat Poll Temperatures 90
description: "Workaround issue with T6 not always reporting temperatures"
mode: single
max_exceeded: silent
- platform: time_pattern
minutes: "/10"
- platform: homeassistant
event: start
- delay: 90
- action: zwave_js.refresh_value
continue_on_error: true
entity_id: sensor.t6_pro_z_wave_programmable_thermostat_with_smartstart_air_temperature
refresh_all_values: false
- delay:
seconds: 2
- action: zwave_js.invoke_cc_api
entity_id: climate.t6_pro_z_wave_programmable_thermostat_with_smartstart
command_class: "66"
endpoint: "0"
method_name: get
parameters: []
- delay:
seconds: 2
command_class: "67"
endpoint: "0"
method_name: get
parameters:
- 1
- delay:
seconds: 2
command_class: "64"
endpoint: "0"
method_name: get
parameters: []
