Thermostat shows wrong status
I have a issue with my Thermostat BWTH from HomematicIP running through a CCU3 and the HACS Integration.
It shows the wrong status. Everything else works as it should.
E.g. in the room I’ve 19 degrees, I set the thermostat to 22 degrees through Home Assistant. The Valve opens and shows in the CCU3 as open. But the Home Assistant Card shows inactive. When I turn the thermostat to 16 degree, the valve closes, shows as closed in the CCU3 but HA says it’s heating.
I have some Meross thermostats, too. They work like intended.
Sounds like an issue with the custom integration you’re using. I’d ask over on their github page.
