Hi!
I have a question about a thermostat swtich of my radiator. In the past, I was using this device with ZHA with USB Zigbee and the thermostat had a battery sensor as well. Now, I have tazmotized my sonoff zigbee bridge and I don’t use ZHA anymore. All good, I have temperature sensor, I have the temperature swtich, but I don’t have the battery sensor anymore, could this be coded and I can’t see the name? How can I extract the battery sensor with tasmota, from this thermostat? Anyone knows?
Thank you in advance
Nobody with this problem?
I think I found the solution.
For everyone which uses Tuya Climate with a tasmotized zigbee bridge from sonoff, If you want to know the battery status of the device, don’t search for “battery”… you should search for this string “EF00/016E” which will have two values. 0 and 1 which means 5% battery and 100% battery (There are no other values). When the battery is low, it will publish these two values till you change the batteries.
I made an automation in home assistant which will send me a notification every hour (this is very important because if you let home assistant notify your phone very time the value changes, you will reach the 500 limit notification)
Good luck
This is the device involved in the subject
