Thermostatic Radiator Valve Obtained Temperature Replacement With Temperature Sensor From Room
Heyy!
I’m looking for a solution to regulate my room temperatures - each room has a zigbee radiator valve for a room (doesn’t need to be thermostatic, but as far as I know they all are) and this valve need to obtain temperature from a simple temperature sensor in a room. Temperature would be set via phone, tablet etc.
Best what I’ve found is from Moes - Smart Brightness Thermometer Temperature and Humidity Detector — MOES
Looks ridiculous because of huge light level value but developer say it will work with their trv.
Maybe someone can help me with solutions?
Have you looked at the generic thermostat?
