Thessla Green Integration
Hey everyone,
Since I’m moving away from YAML configuration whenever I can :stuck_out_tongue:
I decided to turn one of my YAML setups into a proper integration. The amazing HA community already covered most stuff, but a few things were still missing. So I chose to make an integration for the Thessla Green heat recovery unit.
Until now, you had to set up Modbus TCP in YAML and manually configure all the addresses. With this integration, you just need to provide the IP address, port, and slave ID — that’s it! :slightly_smiling_face:
Since I made it for myself anyway, I figured I’d share it with you this holiday season :christmas_tree: Maybe someone will find it useful:
:point_right: https://github.com/aLAN-LDZ/ThesslaGreen_HA
Perks of using the integration:
  • Unique IDs for all entities
  • The operation mode switch is now a cleaner select entity
If I find the time, I’d love to add a custom Lovelace UI card tailored specifically for this device in the future.
You can add the integration through HACS and configure it via the UI. If you spot any bugs, let me know! :slightly_smiling_face:
Currently tested with:
:white_check_mark: Thessla Green Air Pack4
Happy holidays! :santa:
add all sensor
fix for reconnect
custom update interval : 5s tested with EW11
and all small features :stuck_out_tongue:
@alladyn21 Did you consider supporting non-TCP modbus usb interfaces?
Thank You!
How to connect thessla green airpack to modbus tcp? I have AirMobile, are there any instructions ?
hi @jmichal,
here is paragraph and photos that answer your question:
