Thinking of integrating HA in my home
Hi everyone! :wave:
I’m new here and getting back into smart home automation.
I have some background in smart homes (courses in trade school), but it’s been a while since I’ve really worked with it. I want to make sure I start on the right foot as I get back into it.
My current setup (nothing purchased yet)
-Apartment (~1070 sqft) in Quebec
-Heating: mini-split heat pump + electric baseboards
-Thinking of buying Sensibo Air (or Pro) for the heat pump
-Planning to use smart Wi-Fi or Z-Wave line-voltage thermostats for the baseboards
-Planning to run everything through Home Assistant
Looking forward to learning from the community — thanks!
Welcome! It’s a fun hobby for sure. (And as time and budget consuming as you let it… :slight_smile: )
Everything you listed is very doable in Home Assistant, and does not require high-end hardware. Ecobee thermostats should probably be on your short list.
Some advice on getting started…
  • Use this forum a lot. The support and suggestions here are fantastic.
  • Watch out for YouTube videos more than a year or so old. HA changes fast and “how to” videos rapidly become out of date. (This also means AI helpers are frequently outdated as well.)
  • HA is not a “set it and forget it” system. It requires ongoing tinkering and adjusting to get it the way you want it. (While some will disagree with this view, I think it’s helpful as general advice and expectation-setting for any newcomer).
  • Smart switches, not smart bulbs! Unless you have specific reasons for color changing bulbs, the home feels more “in your control” and is more practical if the automation controls a wall switch instead of a smart bulb. This will let you (and your guests) manually use the wall switches as normal.
  • Don’t try to think of everything ahead of time. Let things evolve as you gain experience.
  • Have fun!
This is a good resource:
