Third Reality MK1 Keyboard Blueprint
Control your Matter-based MK1 keyboard’s Matter Button+F1–F12 keys in Home Assistant.
I’m pretty green at making blueprints for home assistant but I wasn’t able to find one for my new third reality keyboard that has matter buttons. So, I made one. If you find any issues with it or are able to help me make it cleaner let me know. Hopefully, I set up the import button correctly too.
This should make a relatively simple way to use your keyboard to set scenes, toggle lights/ switches, activate scripts and other things you’d like to happen with a button press.
Features
  • Select your MK1 Matter keyboard in UI
  • Assign custom actions to Matter Button+F1…F12
  • Only triggers on initial key press
Hello blake.dubiel,
Your link is broken.
This will help you fix it.
Create a link – My Home Assistant
Thank you, I believe it is fixed now.
