This device is buggy and sends large negative meter report from time to time
Hi All,
With some Zwave devices i see this text:
Would be nice that HA filter out those negative reports
What about other sensors that only output those large negative results? Filters like this belong in HA, not in the driver. Use the filter integration.
I do not know about Zwave, but in Zigbee certain negative numbers indicate that there is no (valid) data.
In the past I was told that there was no value for that in HA. Maybe now there is and then it ideally is recorded as such.
I dont see a filter integration
https://www.home-assistant.io/integrations/#search/Filter
haha, i was checking in the integration section in HA itself :slight_smile: stupid me :slight_smile:
Yeah that only lists integrations able to be set up via the UI.
