In the documentation of apexcharts-card, it says:
Supported formats:
yellow
,#aabbcc
,rgb(128, 128, 128)
orvar(--css-color-variable)
For those of you who would like to use other formats like color-mix
, you can achieve this using card_mod:
card_mod:
style: |
.apexcharts-series:nth-of-type(1) path {
stroke: color-mix(in srgb, var(--md-sys-color-primary-dark), var(--primary-color) 25%) !important;
If you have multiple lines in your graph, simply copy and paste the selector and replace “(1)” with the respective numbers.
It took me hours as a noob to figure this out, especially since no one else seemed to have exactly the same problem.
