This must be explain some in full but I can't find it
How does scope and namespaces work. I’ve come from real languages, don’t just give me a line of code show me a working example of {% %} in define variables and IF blocks that don’t loose their values due to weird scope rules.
I keep seeing namespaces reference but every use I try is an error or just gets removed from the code block when saved and returned too.
This is the most temperamental editor and language I’ve ever been subjected too. If you save it and the save button goes away, don’t just deleted blocks of code you don’t like!
Examples in the forum are all code blocks/snippets but have no context and are not repeatable for real world testing or learning.
Try add this element and then reference YAML, most of the time you don’t even know the starting point?
This is more of a general Jinja issue, so try searching for Jinja and scope.
Here is one example of a search result:
