This site can’t be reached - took too long to respond
I have Home Assistant (v 0.102.3) installed in a Docker folder on my Synology station. I have only recently been in the early stages of setting it up by adding some components from HACS.
Today, I tried to open HA and got “This site can’t be reached”.
The last time I worked with it was 2020-01-31 and I doo not recall receiving any error messages.
However the log which follows shows many errors on different issues. Not sure how to sort this out and would appreciate some suggestions.
Thanks,
Kerry
Log There are about 30,000 characters shown here ouf 400,000 plus due to the character limit imposed by this forum.
2020-01-02 07:38:33 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-01-02 07:38:50 WARNING (MainThread) [homeassistant.setup] Setup of default_config is taking over 10 seconds.
2020-01-02 07:39:24 ERROR (MainThread) [hacs] Could not set logging level to debug, logger is not enabled
2020-01-02 07:39:28 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-01-03 23:40:49 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File “/config/custom_components/hacs/hacsbase/init.py”, line 302, in recuring_tasks_installed
await self.factory.execute()
File “/config/custom_components/hacs/hacsbase/task_factory.py”, line 24, in execute
await asyncio.gather(*self.tasks)
RuntimeError: cannot reuse already awaited coroutine
2020-01-05 15:41:45 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-16 05:01:29 ERROR (MainThread) [hacs.factory] GitHub returned 502 for https://api.github.com/repos/iantrich/podcast-card/releases
2020-01-16 05:01:33 ERROR (MainThread) [hacs.factory] GitHub returned 502 for https://api.github.com/repos/custom-components/gpodder/releases
2020-01-20 02:20:17 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 02:33:02 ERROR (MainThread) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2020-01-20 02:50:13 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 03:20:14 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 03:50:15 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 04:20:16 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 04:50:17 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 05:20:17 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 05:50:18 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 06:20:19 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 06:50:20 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 07:20:20 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 07:50:21 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 08:20:22 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 08:50:23 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 09:20:24 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 09:50:24 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 10:20:24 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 10:50:25 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 11:20:25 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 11:50:26 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 12:20:27 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 12:50:28 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 13:20:28 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 13:50:29 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 14:20:30 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 14:50:30 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 15:20:31 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 15:40:11 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File “/config/custom_components/hacs/hacsbase/init.py”, line 320, in recuring_tasks_all
2020-01-20 15:50:32 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 16:20:32 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 16:50:33 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 17:20:33 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 17:50:34 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 18:20:35 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 18:50:36 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 19:20:37 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 19:50:38 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 20:20:38 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 20:50:39 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 21:20:39 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 21:50:39 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 22:20:40 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 22:50:41 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 23:20:42 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-20 23:50:42 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 00:20:42 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 00:50:43 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 01:20:43 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 01:50:44 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 02:20:44 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 02:50:45 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 03:20:46 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 03:50:47 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 04:20:47 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 04:50:48 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 05:00:12 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
