Thousands of "homeassistant hassio_dns[1217] [INFO]" entries in log
I get thousands of homeassistant hassio_dns[1217] [INFO] entries in my logs, which makes the logs a) huge and b) very difficult to read. Is there a config setting somewhere to make the dns less chatty for its INFO logging?
I get these messages generated every hour for about 5 or 6 seconds when I get hundreds of entries in the log. For now, I’ve setup a discard rule in my rsyslog conf, but I’d rather now generate them in the first place if possible.
you can adjust log level of hassio_dns via cli
ha dns  options --log-level=warn
Thanks @eugenebnd
Not working here. I’m using the Advanced SSH & Web Terminal, and entering the command apparently works (“Command completed successfully”). In the system log, I can see a line appearing after entering the command:
INFO (MainThread) [supervisor.api.middleware.security] /dns/options access from a0d7b954_ssh
also sounds good so far. But it does not change anything.
Then I tried
ha dns options --log-level=info
just for curiosity, and I got back:
INFO[0000] No configfile found
Is it possible that it is no longer working, because there is no config file? Shouldn’t it be there? I’m on HA Supervised, running on a freshly set-up Debian VM.
