Thread matter
I’m trying to setup my first thread/matter device.
for hardware I have
I am trying to add “open thread border router”, but it asks for a URL and I have no idea what to give it.
I setup the add-on and it says has references to port 8080 and 8081.
However neither the IP for my SLZB-06P7 nor my home assistant ip work.
Please help
I don’t know if this helps you but earlier this week I added my first Matter devices and was able to do that using the Iphone HA App, through “Add Device”.
I am also setting mine up through my android phone, but I believe I am having 1 of 2 issues. First, I don’t know what port number to point the thread “add-on” to for my SLZB-06P7.
Second it asks for a URL when I go to integrations and try to add “open thread border router” and I have no idea what to put in that field.
Is it the IP and port for home-assistant or the SLZB-06P7 (tcp/ip) and which port.
When clicking on Add Device in my phone App, it asked me what kind of device and I selected Matter. It then asked me to scan the Q-Code and “voila” it worked.
Did you follow this guide to setup the OTBR add-on to connect to the SZLB over the network?
Once OTBR is up and running, you should see the Border Router in the Thread Integration’s CONFIGURE page, which shows a list of all TBRs detected (but not managed) by Home Assistant.
When the OTBR Integration is linked to the add-on (setup by default in HAOS) there should be no need to “add open thread border router” via URL. Review the Thread documentation if you need to manually link the add-on to the integration, and be sure to sync the credentials to your Android phone before adding your first device.
After hours of search I found said guide.
So I put in the values.
I got a prefered network to show up in thread.
I went to configure the device and now it gets slightly further.
I says it find the device and start going through the motions.
Then it says “connecting to my network ”
Here’s a log file.
0:00:00.172 [N] RoutingManager: Local on-link prefix: fd9a:29cc:eed3:8860::/64
s6-rc: info: service otbr-agent successfully started
s6-rc: info: service otbr-agent-configure: starting
s6-rc: info: service otbr-web: starting
s6-rc: info: service otbr-web successfully started
00:00:00.205 [N] Mle-----------: Role disabled -> detached
00:00:00.219 [N] P-Netif-------: Changing interface state to up.
[21:32:19] INFO: Starting otbr-web...
00:00:00.259 [W] P-Netif-------: Failed to process request#2: No such process
00:00:00.262 [W] P-Netif-------: Failed to process request#6: No such process
[INFO]-WEB-----: Running 0.3.0-b067e5ac-dirty
listenAddr not specified, using default ::
[INFO]-WEB-----: Border router web started on wpan0
Default: mDNSPlatformSendUDP got error 99 (Cannot assign requested address) sending packet to ff02::fb on interface fe80::5018:7eff:fe2e:c935/vethd3bf7f4/20
[21:32:19] INFO: Enabling NAT64.
00:00:00.301 [W] P-Netif-------: Failed to process request#7: No such process
Done
Done
Done
s6-rc: info: service otbr-agent-configure successfully started
s6-rc: info: service otbr-agent-rest-discovery: starting
[21:32:20] INFO: Successfully sent discovery information to Home Assistant.
s6-rc: info: service otbr-agent-rest-discovery successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
Additional logs:
025-06-11 19:31:12.044 (MainThread) INFO [matter_server.server.device_controller] Starting Matter commissioning with code using Node ID 1.
2025-06-11 19:31:42.050 (Dummy-2) CHIP_ERROR [chip.native.CTL] Discovery timed out
2025-06-11 19:31:42.050 (Dummy-2) CHIP_ERROR [chip.native.ZCL] Secure Pairing Failed
2025-06-11 19:31:42.051 (Dummy-2) WARNING [chip.ChipDeviceCtrl] Failed to establish secure session to device: src/controller/python/ChipDeviceController-ScriptDevicePairingDelegate.cpp:96: CHIP Error 0x00000003: Incorrect state
2025-06-11 19:31:42.051 (MainThread) ERROR [matter_server.server.client_handler] [548285206160] Error while handling: commission_with_code: Commission with code failed for node 1.
2025-06-11 19:32:06.812 (MainThread) INFO [matter_server.server.device_controller] Starting Matter commissioning with code using Node ID 2.
2025-06-11 19:32:36.817 (Dummy-2) CHIP_ERROR [chip.native.CTL] Discovery timed out
2025-06-11 19:32:36.817 (Dummy-2) CHIP_ERROR [chip.native.ZCL] Secure Pairing Failed
2025-06-11 19:32:36.817 (Dummy-2) WARNING [chip.ChipDeviceCtrl] Failed to establish secure session to device: src/controller/python/ChipDeviceController-ScriptDevicePairingDelegate.cpp:96: CHIP Error 0x00000003: Incorrect state
2025-06-11 19:32:36.818 (MainThread) ERROR [matter_server.server.client_handler] [548285206160] Error while handling: commission_with_code: Commission with code failed for node 2.
additional logs:
22:07:40.186 [N] RouterTable—: Allocate router id 53
22:10:33.343 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:96, chksum:fdd2, ecn:no, to:badcbfd388c4f313, sec:no, error:NoAck, prio:net, radio:15.4
22:10:33.343 [N] MeshForwarder-: src:[fe80:0:0:0:cc3d:b7c2:1526:9a26]:19788
22:10:33.343 [N] MeshForwarder-: dst:[fe80:0:0:0:b8dc:bfd3:88c4:f313]:19788
22:10:34.344 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:96, chksum:fc02, ecn:no, to:badcbfd388c4f313, sec:no, error:NoAck, prio:net, radio:15.4
22:10:34.344 [N] MeshForwarder-: src:[fe80:0:0:0:cc3d:b7c2:1526:9a26]:19788
22:10:34.344 [N] MeshForwarder-: dst:[fe80:0:0:0:b8dc:bfd3:88c4:f313]:19788
22:10:35.525 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:96, chksum:9a19, ecn:no, to:badcbfd388c4f313, sec:no, error:NoAck, prio:net, radio:15.4
22:10:35.525 [N] MeshForwarder-: src:[fe80:0:0:0:cc3d:b7c2:1526:9a26]:19788
22:10:35.525 [N] MeshForwarder-: dst:[fe80:0:0:0:b8dc:bfd3:88c4:f313]:19788
22:12:07.838 [N] RouterTable—: Release router id 53
22:17:14.457 [N] RouterTable—: Allocate router id 56
22:19:58.290 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:96, chksum:10f1, ecn:no, to:36609c3216b3a7f9, sec:no, error:NoAck, prio:net, radio:15.4
22:19:58.290 [N] MeshForwarder-: src:[fe80:0:0:0:cc3d:b7c2:1526:9a26]:19788
22:19:58.290 [N] MeshForwarder-: dst:[fe80:0:0:0:3460:9c32:16b3:a7f9]:19788
22:19:59.411 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:96, chksum:ab54, ecn:no, to:36609c3216b3a7f9, sec:no, error:NoAck, prio:net, radio:15.4
22:19:59.411 [N] MeshForwarder-: src:[fe80:0:0:0:cc3d:b7c2:1526:9a26]:19788
22:19:59.411 [N] MeshForwarder-: dst:[fe80:0:0:0:3460:9c32:16b3:a7f9]:19788
22:20:00.437 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:96, chksum:9ecd, ecn:no, to:36609c3216b3a7f9, sec:no, error:NoAck, prio:net, radio:15.4
22:20:00.437 [N] MeshForwarder-: src:[fe80:0:0:0:cc3d:b7c2:1526:9a26]:19788
22:20:00.437 [N] MeshForwarder-: dst:[fe80:0:0:0:3460:9c32:16b3:a7f9]:19788
22:21:32.900 [N] RouterTable—: Release router id 56
1d.20:32:33.834 [N] RouterTable—: Allocate router id 34
1d.20:35:26.504 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:96, chksum:0b4a, ecn:no, to:1e3855cb138af748, sec:no, error:NoAck, prio:net, radio:15.4
1d.20:35:26.504 [N] MeshForwarder-: src:[fe80:0:0:0:cc3d:b7c2:1526:9a26]:19788
1d.20:35:26.504 [N] MeshForwarder-: dst:[fe80:0:0:0:1c38:55cb:138a:f748]:19788
1d.20:35:27.511 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:96, chksum:4e49, ecn:no, to:1e3855cb138af748, sec:no, error:NoAck, prio:net, radio:15.4
1d.20:35:27.511 [N] MeshForwarder-: src:[fe80:0:0:0:cc3d:b7c2:1526:9a26]:19788
1d.20:35:27.511 [N] MeshForwarder-: dst:[fe80:0:0:0:1c38:55cb:138a:f748]:19788
1d.20:35:28.620 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:96, chksum:a2ec, ecn:no, to:1e3855cb138af748, sec:no, error:NoAck, prio:net, radio:15.4
1d.20:35:28.620 [N] MeshForwarder-: src:[fe80:0:0:0:cc3d:b7c2:1526:9a26]:19788
1d.20:35:28.620 [N] MeshForwarder-: dst:[fe80:0:0:0:1c38:55cb:138a:f748]:19788
1d.20:37:01.529 [N] RouterTable—: Release router id 34
1d.20:43:59.607 [N] RouterTable—: Allocate router id 47
1d.20:45:50.780 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:83, chksum:3000, ecn:no, to:0xbc00, sec:yes, error:NoAck, prio:normal, radio:15.4
1d.20:45:50.780 [N] MeshForwarder-: src:[fd84:f920:a927:3003:7bf9:5294:e909:7d94]:53538
1d.20:45:50.780 [N] MeshForwarder-: dst:[fd84:f920:a927:3003:9b5a:1f2f:74c:df5d]:49154
1d.20:47:26.664 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:96, chksum:39e8, ecn:no, to:da36d47dda9224b1, sec:no, error:NoAck, prio:net, radio:15.4
1d.20:47:26.664 [N] MeshForwarder-: src:[fe80:0:0:0:cc3d:b7c2:1526:9a26]:19788
1d.20:47:26.664 [N] MeshForwarder-: dst:[fe80:0:0:0:d836:d47d:da92:24b1]:19788
1d.20:47:28.036 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:96, chksum:0d92, ecn:no, to:da36d47dda9224b1, sec:no, error:NoAck, prio:net, radio:15.4
1d.20:47:28.036 [N] MeshForwarder-: src:[fe80:0:0:0:cc3d:b7c2:1526:9a26]:19788
1d.20:47:28.036 [N] MeshForwarder-: dst:[fe80:0:0:0:d836:d47d:da92:24b1]:19788
1d.20:47:29.092 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:96, chksum:8e47, ecn:no, to:da36d47dda9224b1, sec:no, error:NoAck, prio:net, radio:15.4
1d.20:47:29.092 [N] MeshForwarder-: src:[fe80:0:0:0:cc3d:b7c2:1526:9a26]:19788
1d.20:47:29.092 [N] MeshForwarder-: dst:[fe80:0:0:0:d836:d47d:da92:24b1]:19788
1d.20:48:59.501 [N] RouterTable—: Release router id 47
Default: mDNSPlatformSendUDP got error 99 (Cannot assign requested address) sending packet to ff02::fb on interface fe80::6dae:206a:a866:4bd/wlan0/3
1d.21:14:14.880 [N] RouterTable—: Allocate router id 34
1d.21:17:05.011 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:96, chksum:7d5b, ecn:no, to:c255faba4ad0533b, sec:no, error:NoAck, prio:net, radio:15.4
1d.21:17:05.011 [N] MeshForwarder-: src:[fe80:0:0:0:cc3d:b7c2:1526:9a26]:19788
1d.21:17:05.011 [N] MeshForwarder-: dst:[fe80:0:0:0:c055:faba:4ad0:533b]:19788
1d.21:17:06.708 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:96, chksum:0901, ecn:no, to:c255faba4ad0533b, sec:no, error:NoAck, prio:net, radio:15.4
1d.21:17:06.708 [N] MeshForwarder-: src:[fe80:0:0:0:cc3d:b7c2:1526:9a26]:19788
1d.21:17:06.708 [N] MeshForwarder-: dst:[fe80:0:0:0:c055:faba:4ad0:533b]:19788
1d.21:17:07.724 [N] MeshForwarder-: Failed to send IPv6 UDP msg, len:96, chksum:18e5, ecn:no, to:c255faba4ad0533b, sec:no, error:NoAck, prio:net, radio:15.4
1d.21:17:07.724 [N] MeshForwarder-: src:[fe80:0:0:0:cc3d:b7c2:1526:9a26]:19788
1d.21:17:07.724 [N] MeshForwarder-: dst:[fe80:0:0:0:c055:faba:4ad0:533b]:19788
I was able to set it up via alexa, but not google home either.
