I’m using the platform: pulse_meter to calculate the speed as well as the distance of my treadmill.
After booting the node the speed is ‘nan’
If my dog is running on the treadmill it show the correct speed/distance!
But if the treadmill stops it takes ‘timeout’-time (see yaml) to set the speed to 0!
That is like expected
But after another ‘timeout’-time the speed is set to ‘nan’.
Is there a way to avoid this?
- platform: pulse_meter
pin: $PIN_COUNT
internal_filter: 150us
unit_of_measurement: 'km/h'
state_class: measurement
accuracy_decimals: 1
internal: false
internal_filter_mode: PULSE
timeout: 3s
filters:
- multiply: $g_r_multiply
- debounce: 5ms
- throttle_average: 5s
total:
unit_of_measurement: 'km'
internal: false
filters:
- filter_out: nan
- multiply: $g_r_KM_PER_PULSE
accuracy_decimals: 4 # All other options from Sensor.
on_value:
- lambda: |-
// calculate max speed
if((double)id(mill_speed).state > id(g_dbl_max_speed)){
id(g_dbl_max_speed) = id(mill_speed).state;
id(s_max_speed).publish_state(id(g_dbl_max_speed));
